I have compared AC vs DC on heaters for linestages and phono stages, with somewhat inconsistent results. With two linestages, AC was the clear winner sonically. The DC supply sounded sharper and crisper, perhaps slightly more detailed but recessed in the midrange, not as natural to my ears. Based on that experience, I have used AC heaters in all of my homemade linestages, DACs and power amps.
The outlier experience was with a phono preamp. Common wisdom says you need DC to avoid noise in a phono stage, but that’s not entirely true. In my case, my phono is a 2-stage affair with a high-gain input tube (D3a) followed by passive RIAA eq and then a lower gain 5687 and output transformer. The input tube needs DC but the second tube can use AC without noise problems. The outlier part occurred when I was trying a Type 27 output tube instead of the 5687. The 27 had some noise with AC on the heaters; DC eliminated the noise and also sounded better.
By the way, Ypsilon phono stages follow a similar approach to what I tried. They use DC on the input tube and AC on the second tube.
