Thought I'd share with you guys the preamp I've been using for the last year and half. It's the First Sound Presence Deluxe MkIII-SI, a 3-chassis unit w/ the Paramount Special Edition upgrade using Audio Cap copper capacitors.
The First Sound preamps are essentially "bespoke" preamps, each one crafted and tuned specifically for the owner's system and system components. The design is a true dual-mono design, essentially two preamps in one main control chassis "box" and not one, but two external power supplies, Shunyata Research umbilicals, and the "special edition" upgrade.
The power supply has 145,200 uF of capacitance/channel for a total of 290,400 uF of power supply capacitance to maximize performance while minimizing the impact of noise and vibration on the main circuit. Additionally, there are two chassis in in the main control unit, with an inner chassis comprised of copper-plated steel to function as a Faraday cage to further reduce the impact of external noise.
Special care is also provided to provide vibration-damping and even the fasteners were selected based on comprehensive, long-term, listening tests.
Notable are hand-assembled volume controls, utilizing individual exceptionally high-quality metal film resistors at each gain position and a massive power supply, exceeding the power supply capacitance and "stiffness" of many high-end power amplifiers.
