MSB Technology Network Renderer Firmware Update V1.11-Audirvana + Playback
catastrofe
106
Saint Louis
MSB will be releasing a new firmware update for their Network Renderer, which allows the use of Audirvana + directly across the network. It will now be possible to select the Renderer as the audio source in A+. Prior to this release, the Renderer could be selected, but playback was not possible.
The firmware update should be available within the next few days in the "Renderer Firmware" section at this link: http://www.msbtechnology.com/about-msb/support/
If you own the Renderer, you can eliminate your NAA/USB connection to take advantage of Audirvana's excellent sound quality.
Weird... I thought Audirvana was using regular UPNP/DLNA... Guess not...
