Miyajima Zero Mono Cartridge VS EMT HMD 025
kozzmo
95
130
140
52
Does anyone out there have any experience with BOTH these cartridges?
Experience with the Miyajima Zero is well documented but I have never been able to find any real comparisons to MONO offerings from EMT, specifically the HMD 025.
Both are 1 mil offerings...I understand the HMD might have vertical compliance and the ZERO does not....
I am getting close to pulling the trigger on a new mono cartridge..but am torn...I can save a little with the EMT...
I have been using a Lyra Dorian mono for more than a decade now, but it's time to move on...
Also wouldn't mind hearing comparisons with either of these cartridges to the more modern monos like the Lyra's....
Thanks
David
Thanks
David
See my post on this subject. If most of your mono listening is reissues then stick with 0.7 mil spherical or modern non-spherical. If you plan to play mostly older microgroove LPs then a 1 mil stylus is appropriate.
https://www.whatsbestforum.com/thre...-cartridge-on-mono-reissues.22938/post-446308
David
curious which pu went with. I’m a Zero owner but considering the EMT to match my SUT. Haven’t heard much about how the HMD sounds relative to the vintage EMT monos or relative to Miyajima.
David, Would love to see this inquiry come full circle and hear about your choice and the outcome to a dedicated mono cartridge.
Can’t remark on your comparison interest as I’ve never heard the EMT, let alone in the same set up.
What I can tell you is the Miyajima 0.7 for me has been a phenomenal insight into modern mono pressings. A dedicated mono cartridge truly is a MUST have. As many others have written, I was bowled over by the palpable fleshiness, a very deep soundstage, a strong sense of rhythm and texture, and a greater fullness of body of these recordings compared to even some very notable stereo cartridges.
3 years late to the party … I recently went from the EMT HMD 025 (with an Auditorium 23 SUT) to a Miyajima Zero (with the Miyajima ETR-MONO SUT). It’s like the difference between hanging out with (1) a smallish, bespectacled, rule-following man in a 3-piece suit, with a German accent, and (2) Art Blakey circa 1955. The Zero is endlessly engaging. There are certainly some euphonic effects. It’s a touch warmer. It’s not the last word in definition. But, perhaps the most enjoyable tone and overall presentation I’ve ever heard.
