MARK LEVINSON ML332 VS ML335 SQ changes
MCLSOUND
105
Hi guys
Look at this as a fully active 3 way setup for example. ...
Whats the main major differences between these series of amps in
Bass
Mid
High
I want to know where the biggest sound quality changes lie..
I dont care about minor changes..
Thanks
MCLSOUND
105
What I was wondering is if the biggerst difference was in only the bass for example then the mids and highs are still very close.
Or if there was a big change in mids..then a 334 or 335 would be best on the mids in a active system
Anyone out there
JackD201
1,429
1,820
Manila, Philippines
I wish I could help MC but I only owned the 332. I jumped directly to the 4 series after that.
MCLSOUND
105
Thanks jack
I heard the 436 with salon2 ..
Did not ...love it...was fine though
Found it dull on top and bottom was dry..
Could have been everything else. .
Love the 33x series for looks but trying to get some reviews. .
Especially anyone who tried ATC..PMC...PROAC...DYNAUDIO..ETC
JackD201
1,429
1,820
Manila, Philippines
I know some folks in www.wiredstate.com that have 33* combos with Dynaudios. You might try there. Do say upfront that you are in the US though. That way they will answer you in straight english as it is a Filipino forum. You might try PMing Sinar. She has multiple 3 series amps from the 331 to the 33H. Tell her I sent ya. ;)
