If you look at Tara Labs they have some really low capacitance (single digit) figures. I was looking at them for phono cables from turntable to the Io.
Which one did you select, Dan?
It's the 50K input impedance that counts, not the 1K ohms output impedance.
Boy did I mess that up!!!I was rushing off to speedskating practice and put my head on backwards.
LOL ....... or in other words a momentary lapse into 'cranial rectal inversion' !
It's the output impedance that forms a low-pass filter with the total cable capacitance.
So with:
a] Output impedance = 1 kOhm
b] Cable capacitance = 100 pF/foot and 25 feet = total 2500 pF
the 20 kHz response is down 0.5 dB.
and 0.5 dB = 94%
also 10% loss = 0.9 dB
But these calculations are for a 25 foot cable not a 7 foot one.
Actually those are Bill Whitlock's calculations. I just changed 50pF & 50 foot cable to a 100pF and 25 foot cable. Same total capacitance.
While some poorly designed output stages might not like that amount of total capacitance, audio frequency roll-off won't be a problem.
He writes about it in several papers, but I was looking at page #97 of:When we are using some one else calculations it would be nice to include a link to the original.
Because it's almost 2018, it's not 1980 anymore. But if you have legacy equipment, then don't use interconnects with high total capacitance.And why should we consider that a domestic audio output is "poorly designed" because it can not drive a 25 feet cable?
I don't see any problems here.Should we say the same words for anyone having a 100 kohm input impedance?
These is a very old Siegfried Linkwitz post on the subject:
Let's put a little realism into high frequency loss due to long interconnects.
I just measured 2 nF capacitance for a 5 m RCA connector cable that I use with Pluto. That is 400pF/m rather than 100pF/m or less which is typical for interconnects.
If the output impedance from the pre-amp is 1kohm (high) and the input impedance of the power amp is 10kohm, then the effective impedance is 10k//1k or 910ohm.
With the 2nF cable this gives a low-pass 3dB cutoff frequency of Fc = 1/(2piRC) = 87 kHz, which is still far above the needed frequency range. With a typical capacitance cable the cutoff would be at 350 kHz. If the passive pre-amp has 10kohm output resistance Fc would still be 70kHz.
