Looking for a counter depth fridge with total depth ~27" (INCLUDING HANDLES)
ll_Fixx_ll
2
I've searched high and low on the internet but I can't seem to find 36" counter-depth fridge that is only 27" depth including handles! I've found plenty in the 30" total depth range, but my current one is only 27" (grand total) and anything bigger wouldn't fit well. I could probably squeeze up-to a 28" including handles.
Let me know!
Let me know!
Check out Summit... I have used one for 10 years. Good luck
https://www.appliancesconnection.com/summit-al57g.html
Try U-line
Let me know!
Sub-Zero
I replaced my Sub Zero with a U-Line. So much more efficient
Did I misread the request? I thought it said counter depth not counter height. I did not know that ULine makes full height refrigerators with double compressors on top. Double compressors are why we bought the Sub Z.
As for undercounter, I have a Uline combo clear ice maker/refrigerator that is 12 years old. It's spent more time being repaired than it has working. On the other hand, the Sub Z (48" Side by Side) has worked beautifully since day 1. We bought it at the same time as we bought the ULine.
I guess I misread as mine is counter depth. As for problems I guess mine is reverse to yours as we were always repairing our SubZero counter depth
I might have confused some people. I want the fridge to be 36" wide, full height french door (hopefully) fridge/freezer.
Thanks for the suggestion though!
That's how I understood it. Sub Zero makes a French Door 36". I have a friend who just ordered one.
