I remember that one company a few years ago offered to rip all the cds when you bought one of their servers. I forget which. Was it Sooloos? I don't see that offer anymore anywhere.
Olive. Very nice product.
Didn't Olive rip files to a proprietary format that you could not transfer to another device?
Lee
Originally, yes. I believe they allow for customized back now. They are unique in that they actually update the product
based on user feedback.
Key is to make sure you get the data properly arranged for whatever your playback software is.
The only problem with that is that whatever software you use today will be something different in 5 years. That is why I am extremely cautious of any proprietary formats or software-specific schemes.
If you move to a different software platform down the road (or even now), you might have to rearrange things for proper import but that goes with the territory, whoever did the rips.
Sure - the really important part is getting the tags and metadata right. Most software can deal with whatever file names and directory structure you might have as long as the tags are OK.
Yes on the metadata, and some software I've dealt with wants a pretty particular data structure or you wind up having more work to do than necessary.
Sorry, but I don't have time to find another laptop. The problem is that it is not a trivial task - the key bit of information is never specified - that the two USB ports are independent. So, if you plug a USB DAC into one port, and a USB hard disk into the other port, it doesn't conflict.
The only other laptop I've found to be good is the HP Elitebook 2530P (also long obsolete). It has a single USB port on the right side that is independent of the other USB ports.
Is there an easy way to tell (in Device Manager, perhaps?) whether there are independent USB ports?
Not as far as I know. May be Vincent might have ideas..
Can we conclude that adding a PCI or similar adapter card with USB ports to a desktop will solve the problem?
If you do, you know for sure this card has its own IRQ and the DAC is the only device using it.
This is what the SOTM does. Supposedly, it's an "audiophile-grade" USB card, that goes on a PCI(e) slot, so you don't have to work with the internal USB ports.
Apparently, the good performance of the CAPS machines can be attributed to this card.
alexandre
