A sense of flow is definitely a quality I associate with better horn systems and is sometimes also present to some degree in other high efficiency single driver speakers like voxativ. It may be a quality that other topologies also have but I haven’t heard that yet.Yeah understood, Al. I get why it is confusing. It is a term Ked and I seem to use (possibly others although not sure) to describe the ability of a system to sound continuous musically such that one is sucked deeply into the music hypnotically - achieved by seemingly musical phrasing between passages and movements or even sections of a piece. Hope that makes sense.
Once you hear a system with great flow, you can identify the attribute easily enough.
Maybe Kedar can give you his perspective on his definition.
It first gelled with me listening as being a strikingly obvious part of listening to music through both OMAs and Animas. It is also a quality the pap horns do but in a less dominantly obvious way.
My mate and I have discussed this sense of flow at length over the last couple of years.
For me it kind of comes in part in the way notes overlap and provide a seamless sense of continuousness that can be a part of great integrated music making. It may be about the relationship of the uptake of attack and the minutiae of trailing decay. If it had a shape it would be rather sinuous rather than sharp. The edges wouldn’t be absolutely sharply clean but might trail to a fineness that is more the way a honed marble reflects light in a diffused fleshy way as opposed to the clear sharpness of a polished granite.
It is more truthful for me with set amps driving horns but some ss amps can have the quality with horns still. I’d doubt it would be a quality you’d find with class d though.
So it may be about micro dynamic shading and the kind of plasticity in the trails of notes and the way they unfold that comes in real resolution and timbral nuance.
It’s a quality that I love and is one of the principal reasons I have a horn system. Once heard and appreciated it is hard to go without for any length of time.
Flow isn’t as exciting and punchy and for those needing adrenal kick it might be unsatisfying. It is a passive listening state where the music swells and washes over and through you. It takes you to a place of not thinking, not noticing anything in part but simply being within the music in it’s whole.
Sometimes after a few weeks of constant flow and immersion (amongst other things) with the horns I will get the desire to change it up a bit and that’s when I tend to swap over to the big Harbeths for a stint of that additional punch. This is usually just a short lived need and am usually wanting to get back into the horns again and go back into the flow mode within four or five days.
My buddy with the Animas also does this where he swaps over to his Harbeths for a few days every now and then but day in day out the default are his horns and the place of flow as well.
