A wilson Magico type of set up (and many other such speakers) create a constant stage and imaging (in that room, not across rooms)
That's simply not true in the case of Wilson.
Tao, disaster capitalists are absolutely rubbing their hands w glee, there is so much money to be made from recession.
And after this short OT break...
https://www.stereophile.com/content/devore-fidelity-gibbon-x-loudspeaker
Well the review summarized why I love these speakers - dynamics with exceptional "realism" and huge soundstage. They disappear and image very well compared with former Devores. Curiously, Jim didn't use a tube amp which I feel these speakers are designed for - he swapped out his Pass monos which were too lean for PS Audio hybrid amps. He did summarize the differences between the Os and Gibbons nicely - i prefer the more modern, neutral Gibbon X to the O 96, but others will prefer the O with a more shelved top end and warmer bass. It was interesting he said the Xs get rid of a slightly hooded issue with vocals. I also agree with Jim that ultimate bass resolution doesn't exist on a Devore loudspeaker vs a sealed one.
The measurements with a Devore speaker are always interesting because of the tuned bass cabinet, although resonance is improved vs. the old Silverback. JA still doesn't like the second order crossover from midrange to bass creating a recessed lower midrange (that was much improved from the former speaker). However I think with tubes this is somewhat ameliorated and that life isn't all about FR as phase is very important in this region. John Devore says in the comments that in all Silverback installs he's heard, this curve sounded best compared with the alternative (he had a "HT" switch before so users could hear both). So its a computer vs real room issue. I will be curious for @Folsom opinion on this.
I do think the over ripe bass in my room might be an instance of the recessed lower midrange + room suckout in that region (which I've measured before with other speakers) - the combination making bass seem enhanced. So my bass issue could be more of a room caused one and would change in a larger room - and why @Pallen doesn't have any bass issues. In fact, Jim Austin noted the Devores bass was much leaner than the Orangutans (a good thing imo).
How about this effort to reconcile competing views:
As Kedar wrote, we are not talking here about do everything, all out assault systems. With limited scope systems (i.e., not playing complex classical or head-banging rock) retrenching to 1) highly sensitive, 2) small single driver or two-way loudspeakers (whether horn or cone or hybrid thereof), 3) with simple crossovers, 4) which can be driven by low/low-ish power pure, simple circuit amplifiers (SETs, very simple signal path pure class A solid-state) can get you very nice and realistic sound quality without too much fuss, brain damage, space required and expense.
I've always mentioned to Keith that it's going to be hard to reproduce the huge performance jump from Zus to his current Devores, specially since they cost almost the same.
But a meaningful upgrade is possible, that I've no doubt. At a cost, of course.
I think it is a bit of a puzzle. I think larger, more ambitious speakers can get Keith materially better sound, but not without a bigger room being a necessary part of the equation to capitalize on the capabilities of the larger, more ambitious speaker.
Honestly I'm not convinced that buying new speakers is going to get you where you want necessarily..
I don’t think Ked is wrong that there is a very strong tendancy for modern type stereos to sound like they have one flavor... but it isn’t a rule.
It seems to often come from tweaking with things like ground boxes, goofy cords, etc.
I don't discount your experience Bonzo. I can only say my experience with the Magico S5 Mk2's (of which i'm most familiar) has been quite different. They are the most transparent of speakers, and are very revealing of micro detail and ambient queues (provided the upsteam gear & cables are up to snuff). The S Mk2 series have the new diamond-coated BE tweeter which allowed the breakup point to be moved beyond the bandpass, and enabled Magico to remove the crossover’s electrical traps necessary for controlling driver breakup, thereby simplifying the crossover & improving resolution. Some other random things about the S5 Mk2's; they use the same midrange drivers as the M3 (Part No: MAG6004RTC), which are an improved version of the midrange in the MPro. Also they use some very nice caps in the critical position - the new Mundorf Mcap Supreme Evo Silver/Gold in Oil caps.Yes, I have tried various phonos, carts, and recordings through many Magico systems. Differences are very small. Think it is the driver, cross over, or a combo of them with the complex circuitry in the path. Same with Wilson and many others. Avalon can be made good in terms of transparency in cones. I am saying in terms of transparency of recordings to Devore orangutans. Other attributes may vary
Ok...
Well the measurements do explain a few things. I think the answer here is to change your bass, and toe out all the way or no more than 5-10* toe in. You basically have to do that because the tweeter is rather high. It's that or rent the apartment behind you, and tear down the wall so you can pull your speakers way farther into the room (obviously not possible). The midrange will probably be a little hot between the tweeter and down to somewhere around where the phase canceling starts from the crossover. But room gain will help the lower midrange a little. I think that I'd prefer a slightly different crossover between the bass and midrange. I'm not sure how accessible that crossover is to make any modifications, so this is probably out of the question because the only good way to do this is to send it to Texas for a free assessment and a little $ for some parts. I'll cover that more in a PM.
With the above said, I agree the best crossover is no crossover. Whilst I'm enjoying my Magico's, my next pair of speakers will be highly efficient (6 ohms, 96db) and have just one cap in the tweeter. But that doesn't mean Gauder, Magico, or Evolution Acoustic's approach of using Elliptical symmetry crossovers is wrong however.
And oh yeah, KeithR is 100% moving this summer - so no more ocean viewI am in full agreement that a SOTA speaker needs a bigger room and intend to have one. But state of LA living is rooms just aren't that big - I can't imagine more than 20 x 15 in my next home.
I don't find the tweeter hot at all in my setup - nor has Jeffrey_T or Ron who both are quite sensitive to it (and would tell me I hope). My dealer did try the speakers a foot closer together w/o toe-in but preferred the setup you heard. I will revisit toe-in however in light of the measurements posted just to be sure its optimal. Currently its more typical "just inside the inside speaker wall" type angle.
You want to hear differences to the recording with low coloration, then come here my Odeons... If you want to hear differences in the recordings with a bit more coloration come hear my Decware HDTs. Once I mod them, they will do even better with lower coloration I hope...Because I find modded tannoy better - though a bit colored compared to Devore, though still shows differences in recordings. Does other stuff well and goes back to the wall
