KEF LS50 stand and subwoofer
L00k_C
8
Dear All
I have auditioned the LS50 yesterday and they sound great. However, I found that I wanted some more bass in them. The guy in the shop suggested the Rell T-7 and T-9 sub to be connected in parallel. Any ideas?
Furthremore I would also like to knoa what speaker stands are most appropriate. I am currently looking at;
Custom Design FS104 Signature, Partington Super Dreadnought and Partington Ansa 60.
Latsly which hifi amps would you suggest for them?
Any input is welcome.
Thanks
my friend has a pair of the kef LS50 , very nice speakers. never heard them with the Rel subs before
His wife did not like the idea of two big subs in the living room , so he used a pair of atohm furtive subs in black
http://www.atohm.com/enceintes.php?enceintes_ref=14
these can be wall mounted or floor mounted , 300wpc class D amps , for amps he used a croft acoustics pre & power , valve/tube hybrids with partington dreadnoughts
or if your budget can stretch , track 600mm stands are supposed to be a good match. more than the LS50 in fact , they come in black or silver
www.trackaudio.co.uk
Thanks daytona600
I will have a look..
So your friend also required more bass...
yes he wanted more low end , there is bass & one note plodding bass
use stirling broadcast LS3/5a myself on my small desktop set up , nothing below 80hz but what bass it has is truly superb
about the same price as the kef LS50 but different league in sound
try and get a listen to these giant killers
