Distinct undertones of Sarcasm....
http://audiophilereview.com/audioph...iew-or-merely-make-your-system-sound-bad.html
You're reading that too literally. He means (I think) you'll hear distortions due to an improperly damped room environment.Hmmm. Pretty odd suggestions in there like this one: "If the volume on your system is turned up enough there is a point at which either your loudspeakers or your room will begin to distort."
How do you get a *room* to distort?
Hard to write a negative review due to windows rattlingUh, rattle the windows?
...Not a big fan of excessive room treatment and absorption. Kills the dimensionality and emotional connect with my MBL's.
