HiRes The wrong way?
jpetek
140
3
923
AN says that a 44 KHz Fils is MUTCH better then a DSD. As I listen to the Fifth Element DAC they DOWNSAMPLE the Files to 44 khz from for example a 96 Khz Highres. I never heard such a musical Dac again. The Lampi Level 6 goes the same way.
I think it is more important to have for example a perfect output stage than a DSD.
What do you think?
Josef
A bad output stage will make any format and any chip bad.
