But hardware problem would mean a callback of the Devialets or a card exchange - however.
I asked Thierry this morning by mail, too. Now waiting for an answer.
Sorry, but that does not sound like "nothing major" as written 2 months agoAs I mentioned earlier we are working on the issue which involves also the WiFi chip manufacturer. We will issue a new firmware until the end of the year which will improve the stability.
Is someone using an iMac as ´feeder´ for the Devialet and can confirm the following workaround:
1) Apple´s Remote App can be used to wake up the iMac from the iPhone/iPad to run itunes on it.
2) The display of the iMac remains off.
3) AIR is working well in this operating status of the iMac.
Especially point 2 is important to me, when thinking about using an iMac instead of a Mac Mini for itunes.
Edit: Found an info, that making a choice in itunes via Remote App and starting it will switch on the iMac´s display?!
Thx for your answer so far. Could you please find out how your iMac is starting in the other room?! The monitor should be off when you wake the Mac up by Remote App. But does the iMac really switch it on when a track is startet for the Devialet? Would be helpfull.This is how I have set up mine. The Imac is in another room so I am not sure if the monitor switch on or not when woken up from remote. om our profile.
Off for subsequently songs, yes. I suspected that.
But I suppose it will be switched on, when you choose and start another song actively by Remote App later on?!
Thx again for your help!!!
Ah, OK. I understood that wrong. Could you try what happens without energie settings for the monitor? I suppose, it will stay tuned on.I started playing a song an the monitor switched on, it stayed on for 2 minutes (the time I have set on the power settings for Display Sleeps) then the monitor went off.
No idea for what that is good for at all![]()
Hello I am a new user of this forum. I have a Dpremier and I use it with a Mac_mini and Itunes. Do you know, it is possible to use Jriver for Mac ?
I have tried, the Dpremier is known as a sound card, but there is no sound
