Price: USD12000, International delivery from Hong Kong. No Box.
Please PM!
Frequency response:
20 Hz - 27 kHz +0.5dB/-3dB
30 Hz - 20 kHz +/- 0.5dB (unsmoothed!)
Deviation from linear phase: ?10 Degrees
Amplifier power:
2 x 120 Watt (per side); 400 Watt (per Sub)
Idle power, drawn from mains: 16W per LS1
Max SPL:
(about) 105dB
Signal to noise ratio:
114dB (unweighted)
Crossover functions:
1550 Hz - 4th order Linkwitz Riley
70 Hz - 2nd order Linkwitz Riley (3-way system)
sum corrected to linear phase in normal mode,
not corrected in ’low-latency‘ mode.
Supported sample rates:
44.1 - 192 kHz
Via USB with LS1i USB interface: 44.1 - 384 kHz ('DXD'), DSD64 and DSD128
Level:
The default ’0‘ setting of the LS1 remotes volume setting gives 79 dBC at the
listening position with a -20 dBFS reference noise (’K14‘).
Latency:
7.3 ms (2-way)
40 ms (3-way)
5 ms in ’low-latency‘ mode
Current drawn from USB: 250mA.
Maximum allowed USB cable length: 2m
Height: either 1150mm for Hifi use (standard sofa height) or 1450mm for studio use.
Width, Depth: 520mm x 160mm
Cabinet volume: 14 liters
Please PM!
Frequency response:
Amplifier power:
Max SPL:
(about) 105dB
114dB (unweighted)
44.1 - 192 kHz
Level:
Latency:
7.3 ms (2-way)
40 ms (3-way)
