Not so sure about this. Just like all digital induces a digital bi-directional noise, my limited experience with only a few Class D amp mfg’ers tells me that all Class D will likewise induce digital-like bi-directional noise. So it’s not so much whether one decrees it pretty low noise or not, it’s a given that all Class D amps induce this bi-directional noise and if the channels share the same AC inlet, it’s guaranteed they will share that noise between channel.A good class D module is pretty low noise in terms of the 'bi-directional' noise to which you refer. Its often less noise than that generated by a tube amplifier.
I’m aware of Bruno, his reputation, and the accolades that follow him. But that’s not a guarantee that matters have been sufficiently addressed.Bruno Putzeys is the designer of the modules in question and I know he's very careful about radiated noise- he likes to be about 60dB below the required to pass the EU directives (to obtain the CE mark).
So unless something is wrong with a module, radiated noise isn't a thing with this amp.
It seems you are correct in that you are not sure about this.Not so sure about this. Just like all digital induces a digital bi-directional noise, my limited experience with only a few Class D amp mfg’ers tells me that all Class D will likewise induce digital-like bi-directional noise.
Short answer is 'no'. The longer answer is very similar, longer because of the explanation (already given above) as to why.What’s not so given is whether or not this Class D distortion by-product has been sufficiently addressed, right?
That is why I said "I see it as highly unlikely one of his designs would have this problem. All bets are off if there's a malfunction."I’m aware of Bruno, his reputation, and the accolades that follow him. But that’s not a guarantee that matters have been sufficiently addressed.
Our class D amps are monoblocks. The prototypes were not and had to play nice on the same chassis. That happened because we made sure the switching noise was well below the 'recommended minimums'.Do your own Class D stereo amps or even Bruno’s include dedicated AC inlets - one for each channel?
No, it wouldn't. If there's a noise problem, hetrodyning noise will show up whether separate power cords are used or not!!If not, considering we live in an imperfect world, wouldn't it still be best practice to design in dedicated AC inlets just to ensure any bi-directional noise overlooked or remaining does not interchange between channels? Wouldn’t such a minor precaution at least guarantee this bi-directional distortion is not shared / multiplied between channels and put this very common problem to rest once and for all?
lol. Earlier you acknowledged and agreed that bi-directional noise was a universal problem with Class D but now you’re singing a different tune?It seems you are correct in that you are not sure about this. If you have a small sample size and then assume that all things are like that small sample, then its very easy to mislead yourself.
First you downplay the significance of Class D’s universal bi-directional digital-like noise and now you claim it’s only an issue with the two Class D mfg’ers I’ve experience with. Thereby, ignoring anybody else who’s expressed similar concerns with their Class D amp’s bi-directional noise?Short answer is 'no'. The longer answer is very similar, longer because of the explanation (already given above) as to why.
Interesting. Whose recommended minimums?Our class D amps are monoblocks. The prototypes were not and had to play nice on the same chassis. That happened because we made sure the switching noise was well below the 'recommended minimums'.
Assuming of course the designer is measuring and listening for the right things, right?No, it wouldn't. If there's a noise problem, hetrodyning noise will show up whether separate power cords are used or not!!
No. I don't think you read my post properly at that time.Earlier you acknowledged and agreed that bi-directional noise was a universal problem with Class D but now you’re singing a different tune?
I immediately translated your 'bidirectional noise' phrase to simply mean switching noise. All noise, FWIW is 'bidirectional'; anything not DC is 'bidirectional' as it is AC in nature.First you downplay the significance of Class D’s universal bi-directional digital-like noise and now you claim it’s only an issue with the two Class D mfg’ers I’ve experience with. Thereby, ignoring anybody else who’s expressed similar concerns with their Class D amp’s bi-directional noise?
One recommended minimum to which every manufacturer has to pay attention is the EU directives that one must meet in order to acquire the CE mark for import into the EU.Whose recommended minimums?
One could, and would be wrong in doing so. Switching noise due to its high frequency nature is just like RFI (it is literally the same thing) in that its insidious. It can radiate through the air, through ground connections, through various bits of wire and certainly does not need to be in the same box to be a problem!Couldn’t one easily interpret your response as… You initially prototyped Class D stereo amp chassis’ but the 2 channels could not “play nice” sharing the same chassis i.e. same AC inlet?
Monoblocks are preferred if you want to get the most out of your system. This is because they can be placed as close to the speaker as possible, thereby keeping speaker cables short. Long speaker cables, especially if the speakers are 4 Ohms (or less), rob the system of bass impact and resolution. I don't like putting my equipment stand between the speakers as that means the front end of the system will be subjected to more energy from the loudspeakers. So I like to place it elsewhere and run long (balanced) interconnects to the amps; since our equipment supports AES48 we can run interconnect cables 100 feet without any coloration or degradation.Why else might a designer entirely abandon their resource-consuming stereo chassis prototype designs and testing and instead go the monoblock route?
Yes. You simply drew the wrong conclusion for why they might exist. Its not to eliminate problems of two channels in the same box as that would never work. If the two modules can't play nice in such a situation you have a serious problem; either a malfunction or a design flaw. Its occurring to me that you might not understand how quiet a class D amplifier actually has to be in order to work right. If its got a problem, the fact that its in one box or two will not prevent noise from getting into the system and being a problem.Wasn’t Class D monoblocks (or dual AC inlets at the stereo chassis) my point from the git-go?
Designing a class D amplifier requires a bit of math and a lot of measurement; IME quite a lot more than you might have to go through designing a class A or AB amplifier whether tube or solid state. In addition the equipment needed to make the measurements needed is considerably more sophisticated than you might need for the prior art. IOW anyone who has designed a functional class D module did not do it without a lot of measurement. Your question is a bit of a red herring.Assuming of course the designer is measuring and listening for the right things, right?
I'm simply trying to get you to understand some nuance of how class D works since your initial post to this thread indicated a misunderstanding. For example your phrase 'bidirectional noise' really isn't a thing. Its just switching noise as I explained earlier. You've been laboring under a false impression. I've simply been attempting to disabuse you of that, perhaps too gently.Sorry, but the more you defend, the more my radar goes up.
Clearly we’ll just have to agree to disagree on terminology, significance, and potential remedies.No. I don't think you read my post properly at that time.
Monoblocks allow this; a stereo chassis must be placed between the speakers to keep speaker cables short so will always be less than optimum. This is the reason most of our tube amplifiers are monoblocks too.
You do realize that I don't have a dog in the fight? Whatever is going on with the OP's system, its obviously a malfunction (which might be fixed, since he is absent from this thread at this point). If it was a problem with two modules in the same box, the noise would be constant.
Now you could ask someone who never designed a class D module and see how much accurate information you get. But if you ask someone (and I admit, most class D designers are not active on audio forums like this so that makes this difficult) who has and you'll get answers like mine.
Presumably your post was directed toward me? If so, frankly, I'm unsure any of this "stuff" actually addresses any point I raised.You know I make sound suggestions based on facts no reply
I wonder is it just the trash a product you no longer like or did not like but can’t get a refund
let ralph explain but it can’t be EMI had to be RFI
BE it power or network or anything in between
EMI is magnetic has you thought into how much is needed and how distance makes it become minute in a few feet
tubes can be effected by both but still needs to be close enough if EMI
if there is a router with enabled WiFi even 10 feet away or on another floor or room it can effect things. this is a proven fact and has happened to me
Also most all devices have switching psu now and this includes linaer power supplies
a regulator is also switching as is diodes
So get off the soap box of how you absolutely know it’s your disliked class d amp
Not trying to be rude either but I'm still unable to find a single question mark in your collection of thoughts - so I just assumed you were on some soap box yourself.Not to be dramatic but of course its you and you are still standing in the same place and not Answering a single question I asked
No.Ok do you have a router in your audio room ?
If you do unplug it while you hearing the noise .
Take note does the noise stop .
Incandescent.Next is dimmers , what kind and type bulbs it controls ?
Emphasis added: obviously so. But simply because you are unaware of it happening does not mean anything.Clearly we’ll just have to agree to disagree on terminology, significance, and potential remedies.
Regardless of what anybody calls it, e.g. switching noise, RFI, EMI, or bi-directional noise, etc., bi-directional noise is a real byproduct of Class D operation that can travel back through the shared AC inlet. That’s not in dispute; even excellent engineering can only reduce it, not make it vanish entirely.
And while most noise / distortions are fundamentally technically AC as Atmosphere pointed out, the kind of high-frequency switching hash a Class D amp throws off between channels and linestage is far more invasive than the usually more gentle distortions we’re used to from analog gear as it can leak back into the system through shared AC inlet in a way that really does matter.
It’s also worth noting that without superior passive, dedicated, bi-directional filtering line conditioners this noise can leak to all other components even if they are on separate circuits as some will claim this digital-like distortion can make its way back to the service panel and induce its harm on other circuits too.
FWIW, years ago I ran a few simple experiments that made this clear to me.
Around 2006, I wired the IEC connector of one of my treasured Foundation Research LC 10 passive, dedicated, bi-directional line conditioner to service a pair of NuForce monoblocks, and the added distortions were immediately audible.
I repeated a similar test around 2015 with my current Wyred-4-Sound (W4S) monoblocks and got the same results.
Just prior to taking possession of my W4S monoblocks, I had purchased a Wyred-4-Sound Class D integrated amp (single AC inlet) and the outcome was far worse. The presentation was horrifically unmusical so I swapped it out for the very musical W4S monoblocks I still use today.
Whether or not this kind of noise is audible will always depend on the design, the system, and the listener. My only point here is to inform the OP, given their integrated design, that if you hear something that smells like Class D switching noise, you’re probably not hearing a malfunction, but most likely encountering real bi-directional noise compounding between channels and the linestage. Which, I suppose, could be considered a malfunction if the amp designer claimed to have solved it (like Atmosphere) but it’s still prevalent.
And if per chance the culprit is the bi-directional digital-like noise I suspect, the only reasonable mitigation I’m aware of is to move to Class D monoblocks AND superior line conditioners (highly recommend Jena Labs series of line conditioners).
Many claim Class D amps are quite musical, while many others report hearing, excessive brightness or detail, or digital-like hash i.e. bi-directional noise. That’s where things like monoblocks or dual AC inlets, and superior line conditioning can help mitigate the damage.
That said, I can’t help but think… With Class D’s musical potential even in its current state, if someone had genuinely absolutely minimized this rather obvious bi-directional noise (as Atmosphere claims he has), it would have made breaking headline news by now and far more people would be swearing allegiance to Class D amplification. As of yet, I’m unaware that either has happened.
Agreed.Emphasis added: obviously so. But simply because you are unaware of it happening does not mean anything.
Most of this is nonsense.
All Class D designers or just you?Its not news that class D amplifier designers have sorted out how to keep switching noise down.
Meeting EC directives is good engineering, but as I'm sure you know, compliance rarely translates to silence in real playback systems.We aimed for and achieved 60dB below EC Directives requirements and we were by no means the first to do so. Many tube amplifiers and many class AB solid state amps make more so-called 'bi-directional noise' on the AC line. That noise is generated by rectifiers used in regular power supplies and if its not killed properly in the amp, can radiate at some pretty high frequencies through the air, through grounds and through the AC power.
In our design the rectifier was found to be the main source of noise during testing. We have it snubbed properly (people that know power supply design know what I'm talking about).
Not sure how to respond to this one. You almost make it sound like line conditioners were invented solely for Class D, even though superior (as opposed to inferior) line conditioners can be quite advantageous for 100% analog and Class A and/or B amped systems. And if the line conditioners are bi-directional filtering, they especially benefit when switching artifacts are involved like Class D and digital (DAC, cdp) distortions – both of which happen to be bi-direction.No line conditioners needed.
Bruno Putzeys says pretty much the same thing I just told you. Any class D designer has to be aware of EU directives and the underlying reasons for their necessity. But I don't doubt some try to fudge things...All Class D designers or just you?
It had better! If it does not then its a good bet the CE mark (which can be obtained through self-certification, which means you can lie about it until you get dragged into court...) was not placed on the gear in a legitimate manner.Meeting EC directives is good engineering, but as I'm sure you know, compliance rarely translates to silence in real playback systems.
Right. What you are talking about is hetrodyning, where two noise signals of different frequencies are able to mix and thus generate signals that are the sum of the two and the difference of the two in frequency (the latter of which is likely the main concern). If the two amps are low enough noise then that simply isn't a concern. IMO if placing two modules on the same chassis and feeding them with a common AC cord is a problem, then the modules are simply too noisy regardless of whether they are on a single chassis or not.The issue I raised wasn’t about whether a Class D amp measures clean in isolation, but how Class D’s high-frequency switching artifacts behave once two channels share a single AC inlet and in the case of the OP’s int. amp, the linestage must borrow power from an already bi-directional “polluted” channel. That’s the “bi-directional, digital-like noise” many listeners still complain about - perhaps even the OP of this thread. Yet, you haven’t really addressed that – except to say it’s already “pretty low noise” and you corrected it.
I didn't make it seem as anything- the meaning applied is entirely your own.Not sure how to respond to this one. You almost make it sound like line conditioners were invented solely for Class D, even though superior (as opposed to inferior) line conditioners can be quite advantageous for 100% analog and Class A and/or B amped systems. And if the line conditioners are bi-directional filtering, they especially benefit when switching artifacts are involved like Class D and digital (DAC, cdp) distortions – both of which happen to be bi-direction.
Since both are switching technology, yes, paying attention to stray inductances really helps keep DACs and the like low noise as well.I’m curious. If you’ve truly solved Class D’s bi-directional noise at the source to the point that any line conditioners aren’t needed, then perhaps your same fix could finally cure the bi-directional digital noise that DACs and CD players are notorious for? Especially since that’s exactly what Class D’s artifacts are often likened to?
Such videos are already online.Regardless. Earlier I posted this same in-room video to demonstrate my W4S monoblocks + my fabulous Jena Labs conditioners to show what’s possible. Maybe you (or one of your Class D customers) could post a similar in-room video to demonstrate your design’s claimed immunity to this noise? If you've solved Class D's bi-directional noise issue, I'd love to get a glimpse of its sound.
Thanks for the explanation, Ralph. I’m not a designer and I certainly don’t pretend to be one. My comments are derived only from 15 years of living with Class D amps and running a few simple listening experiments over the years – including a few years of selling them and encountering the same bi-directional issues with their installations.Bruno Putzeys says pretty much the same thing I just told you. Any class D designer has to be aware of EU directives and the underlying reasons for their necessity. But I don't doubt some try to fudge things...
All I was saying is you don't need a line conditioner with a good class D amp since it is silent, producing less noise than many other kinds of electronics (in particular digital devices). Its obvious you understand that if the switching noise of a class D is able to interfere with digital devices it could cause havoc. So anyone really concerned about such noise will make sure their design has that noise so low its simply not an issue.
Its worth pointing out here that with any class D amp on the market you can't hear its switching artifacts unless something is dreadfully wrong because the frequency is way too high!!
What you can hear is the distortion that some amps make and sometimes its not pleasant. If the class D amp is not of the self oscillating variety, then you can have a problem with a quantization noise generated by the switching frequency changing due to drift in the local oscillator. This can be heard as a hiss. Unlike the hiss generated by a phono section or the like, this hiss contains lots of artifacts that can be quite fatiguing. So such a class D amp would have to use something like a crystal controlled oscillator where the crystal is in a temperature controlled oven and then its output divided down to the desired switching frequency. But that kind of noise can't be entirely eliminated.
However if you use a self-oscillating design then that problem is neatly side-stepped and the circuitry is actually much simpler.
Please note that the use of 'bidirectional noise' really isn't a thing because if there is noise of any kind at all, its inherently 'bidirectional'; IOW nothing unique to class D or digital operation.
'Bi-directional' isn't a thing. You are simply talking about switching noise.Thanks for the explanation, Ralph. I’m not a designer and I certainly don’t pretend to be one. My comments are derived only from 15 years of living with Class D amps and running a few simple listening experiments over the years – including a few years of selling them and encountering the same bi-directional issues with their installations.
Sounds like those amps had a serious problem! I didn't take any class D amps I'd heard seriously back then. It was not until about 8 years ago I heard one that had promise. Turns out that was mostly due to the small sample size to which I was exposed.Back around 2007, I recall one doctor client who purchased a pair of nuforce Class D monoblocks and I installed them in his home. He was employing about $7k worth of a popular name brand’s active line conditioners and after about 10 min, I couldn’t take it any more, so I asked if we could take his line conditioners out of the chain. He agreed that it immediately sounded better. So I drove home and grabbed 3 or 4 of my fabulous Foundation Research (now defunct) passive, dedicated, and bi-directional filtering line conditioners and went back to install them. He agreed that his playback presentation was significantly more musical than before and ordered 3 Foundation Research LC-10’s from me.
I can point you to a good number of comments and reviews if you like.Come to think of it, I’m unsure I’ve ever heard or read about anybody loving their Class D amps without also employing superior line conditioning.
That is not what I said. If you look you'll see I said that when you design a class D amp you have to pay attention to stray parasitic inductances in the design, else the unit will radiate noise through the air, through grounds and through the AC power. But I did also say that (paraphrasing) the switching noise is basically RFI as far as other equipment is concerned.Maybe Class D technology has since evolved to the point where such noise is no longer an issue, but thus far I’ve only heard or read such claims from you where you seemed to be in denial stating the noise was already pretty low to begin with and it’s no different than RFI.
I did point out Bruno Putzeys, several times. On that account the above statement is false.And as you just stated earlier that “Its not news that class D amplifier designers have sorted out how to keep switching noise down” to make it sound like all Class D designers had solved this rather significant issue. But again, I’ve only heard such claims from one Class D amp designer – you.
If you wish to sound credible to anyone who knows about class D or digital design, you will avoid using 'bi-directional'. Its not a thing and it makes it sound as if you have no idea of what you're talking about. I think you do have some idea though, so in the future use 'switching noise'.That’s why I keep circling back to system-level audibility rather than compliance numbers or lab behavior. And that’s why my radar remains as high as ever as I can’t help but think you’re in denial that this rather apparent and prominent bi-directional noise was ever an issue.
You’ve given a technical backdrop, but what I’m pointing to is what happens in real playback systems where two channels share the same AC inlet and in this case, the linestage borrows power from an already polluted channel. But I’m also including playback configs where no or inferior line conditioners were employed with any system that included Class D amps. That’s where I and plenty of other listeners have heard the digital-like bi-directional hash or however one wants to label it. So far, I haven’t seen that part addressed directly.
With regard to videos of your Class D amps in action, would you please provide a link to just one that demonstrates your Class D amps’ immunity to this bi-directional noise? I’d love to hear it for myself.
I think a lot of class D amps have had problems and it goes back far further than just two decades! But they had switching noise problems. Your phrasing here (emphasis added) suggests I said something that I didn't which is pretty much the definition of a strawman logical fallacy.which you claimed must be a malfunction because the problems with Class D bi-directional noise never really existed. Despite the fact many of us have experienced much the same thing in our playback configs for the past 20 years.
I can’t help but think… If the OP’s Class D int. amp is simply a malfunction as you claim here, then it seems to me a lot of perfectly functional Class D amps have been “malfunctioning” much the same way for over two decades.
My Ganfet class D amplifiers are dead silent.'Bi-directional' isn't a thing. You are simply talking about switching noise.
Its important when dealing with anecdotes like yours and mine that they suffer from a small sample size, which means that if you draw a conclusion based only on the small sample size, you commit a logical fallacy which will create a blind spot for you (IOW you fool yourself). It is that very reason that prevented us jumping into this technology sooner than we did.
Review: Atma-Sphere Class D Amplifiers
Of course you did. You chose the parts and you chose the circuit according to what you count as good. If part specification alone is how we count as 'good' then this is correct. Every time I've seen anyone talk about 'voicing' though, its been in the context of choosing certain parts to...www.whatsbestforum.com
If you think we didn't listen to our equipment and see how it works in real systems you would be mistaken. We've been making class A triode OTLs for 49 years and we had to be sure that once the class Ds were running right that they also 'sounded' right in comparison to our tube stuff.
The original poster is missing in action so I presume the malfunction was found and corrected.
