Diretta audio protocol
over 2300 euros was invested just to the parts.
Wow! My own Ian Canada + Diretta concoction pales in comparison, but sounds great for less than $500. The trick is using two Raspberry Pi’s linked by a completely isolated network without any other traffic, error correction or control signals.
Explained here.
Just here to say a few things:
1) Thank you so much for this guide.
2) I have had Gentooplayer and Diretta ASIO working on my Holo Red for awhile. For some reason I never had Memory Play and THIS is the way to listen to Diretta. I wish there was a better player interface and it played mp3's, but it is the best for FLAC and WAV by far.
3) You don't need to download and install Diretta Memory Player separately. It is included in Diretta Tools. When you click MPlayCtl from the Tools program it launches the version within the Tools folder anyway. So downloading Memory Player is not needed. Memory Player is offered there separately just in case you are running a Diretta Host somewhere else. There is no advantage to running the Host on a different system if you run everything from Windows.
Reactions: hopkins
Okay, folks, I'd weigh in here on a project a good friend of mine has undertaken. He's convinced me to follow him down the rabbit hole.
Here is the link to the Diretta Project on GitHub
I am currently running this solution on two Raspberry Pi units: A Pi4 running as the Diretta Host and a Pi5 running as the Diretta Target.
As of this morning, I have Diretta Mode3 implementing DDS "Diretta Direct Stream" in place of UDP atop the latest version of AudioLinux 4.6.
While David Snyder, the fellow behind this project, focuses much of his work wrangling Roon, I decided that I'd like for it to be less of a "uni-tasker", so I now have RoonBridge and MPD UPnP and its associated client running in tandem. This way I can run either Roon or Audirvana, but not both simultaneously.
Below, I have screen captures
Roon
Audirvana
AudioLinux
Have fun tinkering, for those who take such pleasure :)
