But the displays look normal as well as the back lit dCS logo.....and the labels aren't white
Photoshop
+1
PS, congrats on the clock !
Thx. What should I expect from clock to improve sonically apart from the technical part that it improves sync hence less jitter. Does it improve continuity and musical flow? Should one also expect impact over dynamic range?
I hear you. I love my vinyl still. Just amazed every time I listen to it. Then I switch to digital...
They both have strengths. Well recorded digital on a dCS Vivaldi is just hard to turn off...
What I hear is on a couple of dimensions:
#1 - seemingly lowering of the noise floor - you simple hear the notes as more defined, the bass gives a better foundation, textures and decays bloom
#2 - everything has it's place. instruments are more distinct both with in the soundstage and your ability to pick out and focus on one. Plus just more 3-d like...
#3 - timing - an example...I have a piano and cello recording. i've always clearly hear both instruments...but with the clock in place you can hear the piano leading the cello..it's subtle...but once you hear it..it's unmistakably conveying the musicians intent better.
Better clock cables matter. Even just going with Cardas and spending ~$300 each is clearly heard. Ditto for power cords/isolation.
Hope that helps !
I have another, perhaps radical, thought. I have been discussing with my Boston audio buddies, the advantages and disadvantages of internal and external clocks. I suppose the same would hold for transports and upsamplers, but perhaps not to the same extent. So here is a question: Would an all in one box approach to the Vivaldi stack sound better than the four box approach, assuming it would be built and designed to the highest standards, that is, have the same quality parts, just packed closer together without the need for expensive external casework and cables?(...)
To that end, has anyone directly compared, say, the AF1 with top arm/cartridge to the dCS stack? The conclusion might take us right back to MikeL's comment.
In my limited experience, I have found that the best sources are exceptionally good if properly set up in the right system, regardless of format, and to a lesser extent, regardless of price. The AF1 and Vivaldi just happen to be similarly priced, and at the top, reference products that some people have heard at shows and dealerships, so I mention them for the sake of argument. And this is WHAT'S BEST FORUM.
I really don't like all the boxes but it is what it is. The cabling dynamic w/dCS is the most troubling part of the system from my view point. dCS should provide the best cables and be done with it. And that includes power cords.
BTW, I've been told the clock doesn't make much of an improvement unless you are using the transport
cool stuff...which piano and cello recording is it?
I have no experience with the AF1 but I have a Clearaudio Master Innovation table and the rest of the equipment you see below. In my system, I don't have a strong preference for one versus the other. I prefer the convenience of my digital setup for long listening sessions or when I'm working with music to accompany me. For concentrated listening, I will listen to either and tend to follow MikeL in terms of preferring music that was originally recorded AAA to be played back on my analog setup, especially for the old mono jazz recordings. More recent music where digital was used for recording, processing, and/or media I tend to prefer my digital setup, usually upsampling PCM to DXD and DSD playing in whatever the native format was (64 or 128). Digital tends to have better dynamics and better bass control. Analog really gets the mids right especially with strings and voices. I enjoy them both.
Hope that helps !
Those sound very promising!
I ordered another Transparent XL clock cable for the clock connections. Since I don't have upsampler, Just 44.1khz based clocking is sufficient. So all I need is two clock cables, one for transport and one for dac. When upsampler comes into equation, cabling complexity increases a lot.
I've been told something similar. So did you skip the clock? What dCS components do you have/use? I assume whatever you have is better than your NADAC?
