dCS Vivaldi Cables?
Kingsrule
1,657
906
1,930
Has anyone actually tried different cables on their Vivaldi stack?
It seems like the defacto go to is Transparent Reference XL clock and AES/ebu cables (especially here in the US) but I haven't seen much talk about any brands in detail.
Really interested in comparisons to Transparent.
I wonder what dCS in England uses as their reference cabling?
The nordost distributor here has the vivaldi stack and also deals in ansuz and audience. He sells ready solutions for the stack, i.e. looms based on your preference. Obviously his first preference is Odin
I'm pretty sure dCS use Valhalla 2 in their reference setup. This came up in a discussion with a dCS rep a few months ago. I'll double check at my end and confirm...
Cheers
Guillaume
Cheers
Guillaume
I started with the Original Valhalla and recently switched to the Valhalla 2. I have not tried the Transparent XL but hear good things about it
DCS endorses both brands. Transaparent Audio have a Vivaldi system in their SOTA listening room.
I know why. It's a great partnership.
Cincy
I've tried a few brands. However on my Scarlatti Stack vs Vivaldi stack. (only used their clock cables b/c dCS at the time were using firewire-I had a Audioquest Diamond) On Scarlatti I had a full loom of digital cables by Cardas. Lightning 15. Then Purist Proteus Provectus Praesto. Then began moving to Transparent as the Vivaldi pieces came in.
All were better than stock. Cardas is a pretty nice jump in performance for not near as much $$'s. Purist were better still. Then when Transparent came out with the current version of Ref XL digital, I tried one...and was hooked. When my upsampler arrived last fall, I used 2 stock AES/EBU (was Van DenHul in the inbox). I was thinking all was just fine until my dealer loaned me a pair of Transparent Ref XL.
What I find is the same signature on digital cables as we hear on the signal cabling. Cardas was warmest...nice mids. Purist beautiful midrange more even and more extended than Cardas. Transparent much more quiet backgrounds, resolution, ease and beauty everywhere.
So my guess, it's best to stick with the brand you like for signal cabling.
Watch out on the clock cabling. Key issue (only issue?) is the 75 ohm impedance spec. Anything different will produce internal reflections. I had our lab test a range of cables and some very upmarket digital cables were not so close to the required impedance.
Right this moment, I can't find the spec for S/PDIF but I found this on balanced AES/EBU cables:
The specification for digital audio was developed jointly by the Audio Engineering Society (AES) & European Broadcast Union (EBU). The key difference between twisted pair specifications for digital audio cable and standard analog audio cable is the impedance specification. AES/EBU, with its broad tolerance, allows cables with impedances from 88 Ohm to 132 Ohm to be used.
Does DCS supply any digital (signal or clock) cables with their equipment?
Yes. In my Vivaldi boxes the clock cables seemed pretty generic, I'd have to look, but something like Beldin. The AES cables were pretty good, Van Del Hul.
Where did you notice great improvement? Replacing the clock or the AES cables?
Actually both. Surprising the improvement better digital cables can make. If you had to do one or the other...I'd do the clock cables first...
I agree with you: clock cables make a big difference. As I mentioned previously, key issue is 75 ohm impedance to minimise internal reflections. Worth trying a decent video cable such as Stereovox component video. Some exotic digital BNC cables from audio cable manufacturers were way out.
I cannot find any Stereovox dealer. Where did you buy it?
Conveniently, 75 Ohm coax is the most inexpensive value for a bulk cable company to manufacture. So even unlabeled coax is probably 75 Ohm impedance.
Bad assumption. The issue is as much to do with the connectors as the cable.
At such low RF frequencies, connectors are not an issue. Nor for that matter are short (1 or 2 meter) coax cables.
The mis-understanding about connectors is caused by digital signals looking somewhat like square waves. So people examine them as infinite frequency square waves. But in fact they are low-pass filtered so they need to be treated as low frequency RF signals. A 44.1/16 S/PDIF signal can be viewed as a 12MHz RF signal.
