Cleaning vinyl, yall got it wrong
Hi-FiGuy
2,241
763
385
Peep this! :eek:
WARNING: THIS IS STUPID SILLY HUMOR, IF YOU CANT LIGHTEN UP FOR A FEW MINUTES DONT WATCH THIS, I CANT "GIVE YOU" THE TIME BACK!
amirm
Banned
Apr 2, 2010
15,813
38
Seattle, WA
I personally favor using meat tenderizer and radiator fluid/antifreeze. The combination works a lot better than the junk he is using as modern antifreeze has lubricating molecules in it that improves cartridge tracking (speeds up transients/improves detail resolution).
Hi-FiGuy
2,241
763
385
I remove water from my records with WD40 as it displaces the water off the surface and lubricates the grooves for extreme friction reduction and lower noise floor.
GaryProtein
2,542
31
385
NY
Hi-FiGuy
2,241
763
385
There I fixed it so as to not rob anybody of their valuable time.
Explicit warning added to OP.
NorthStar
24,305
1,323
435
Vancouver Island, B.C. Canada
I also wasted my time while laughing. ...So maybe it's not such a bad thing after all...it puts life's perspective in check with reality.
I'm also listening to the radio...it helps...classical chamber music...piano, cello, violin, viola. ...Voila.
Hi-FiGuy
2,241
763
385
Perspective is an understatement.
I am wondering if someone thought there was some new cleaning method that had not been tried a thousand times already and felt duped.
It simply made me laugh when I saw it and put into perspective how obsessed we get with cleaning records (myself included)! :p
If you cant laugh at yourself...
