Vibration is caused by the music played!
There is a lot of low frequence energy in the area were the amp's are placed.
I cannot place the amp's on another location.
The amp's are placed between the speakers like ack's setup.
If the vibration comes through the floor then that could explain thatThe strange thing is that the equipment on higher layers don't vibrate that much!!
Any off you guys wanna do a speaker/subwoofer vibration test ?
Place a water glass on top off the speaker/housing and play ear deafening levels , see if you see wrinkles in the water ?
I use a Seismometer app for the iPad and there’d no danger of spilling the water into your components.
It’s pretty sensitive and easy to use.
Cheers
Thx Blue58 i will try.
To reduce the ringing of the heatsinks like ack mentioned i put some isolation pieces between the cooling ribs.
To prevent cooling issues i did the following:
