So, you think it was better when Cessaro used to use wood horns? They switched some years ago to a synthetic horn material (like a synthetic stone type material I think). Did you have that feeling when you used the Horns.pl horns, which are made by out of fiberglass/epoxy? I have some horns.pl horns (iwata 600) that don't seem to have any coloration at all. I also have some nice wood Tractrix horns, which are slightly warmish sounding compared to a plastic or metal horn. The horns.pl is probably them most neutral of the horns I have.I think Cessaro have a «plastic» signature on both vids. Might be the room though
then violin and insight to recordings sounds different in each Cessaro video.
The Kondo and the Euronor have tone better than anything, the insight to different recordings (not reflected in one video) is blocked due to baffle staging.
Plus, in this case it is a mono cart playing mono, and the klangfilm excel at mono because their baffle stage disadvantage is not an issue
The Pnoe sound better to me. They are more relaxed and openSingle driver no crossover vs large 5 way
Yes that is correct I would like to listen to them all and they are all systems that I like.The thread title is about a system, but when you throw in other videos with the same music, you invite comparisons and I presume comments.
Yes, it’s a lot of videos. I presume Bonzo wants the readers to listen to them all.
I posted a lot of videos of the system sounding great Peter. When Ron says he preferred one, that reply was natural. However I wish you would enjoy the videos and the music rather than trying to drive home the point that Tang’s decision to give up Cessaro and move to Eurodyn was the right one. He is not listening to them.Since there’s not much system information, I simply said the wood horn to distinguish that particular video. The video sound, of course, is the result of the entire system in the room and not necessarily the material of the horn. It could be the cartridge or any other element.
I posted a lot of videos of the system sounding great Peter. When Ron says he preferred one, that reply was natural. However I wish you would enjoy the videos and the music rather than trying to drive home the point that Tang’s decision to give up Cessaro and move to Eurodyn was the right one. He is not listening to them. Maybe he should have moved to Kondo from Lamm, Schroeder or ikeda from 3012r, and carts that don’t break.
Very strange response. This has nothing to do with Tang and I never gave that a thought. Your presumption is preposterous. I simply read through this thread and stopped on one post with a direct comparison because I was intrigued by the violin trill title. I listened and commented. Simple as that. I am not alone in preferring the vintage horn in that one comparison.
Cmon Peter, for a video guy quiet throughout the thread and jumping on one post. Please get back to enjoying music and videos we are all aware of tang’s error.
The trill title is because that sonata by Tartini is called Devil’s trill. It is a famous violin virtuoso piece. Tartini dreamt of a devil playing the violin and named and composed that.
It’s fair to not like your own. It is like liking your own posti will watch and comment on other videos. I did sit through all of the Chaconne thread you started and have thoughts on all the videos but since you inserted one of mine without comment, I thought I should not participate much over there.
The Altec system gets pretty muddy sounding when the piano and orchestra are really going at it. The sounds blend together.
The Cessaro keeps it all separated better but is a bit thin in the body of the instruments...especially the massed strings. Piano is clearer than Altec with orchestra playing hard but it also lacks weight.
After that, how 'bout we tackle the myth that horns do female vocals best?
I prefer the wooden speakers where the violin sounds more like a wooden instrument, less synthetic, more natural tone.
