The oMD v2 provided an obvious increase in clarity and transparency, which results in hearing further into the soundstage, more microdetail and faster transients.To clarify, replacing the TP-Link MC220L/iPower X combo with the Optical Module Deluxe/MiniTeddy resulted in an improvement in the same direction the former had improved—less coloration and more microdetail.
Is it possible that with the latter there was also an improvement in any other direction, like soundstage depth and realism, space, better deep bass maybe? Or not significant?
My PlayPoint streamer is connected to the ER B-side. The A-side has the fiber connection, and also ethernet to a TV and Chromecast Audio streamer. I have tried disconnecting the TV and CCA a couple of times and heard no difference whatsoever through the main system PlayPoint. Connecting to the ER makes a major difference to the sound from the TV and CCA.I have to ask, what about optimisation of your eR in the more resolving setup:
- was it used in conjunction with the superior B side of the EtherREGEN, which is designed with "moat isolation” and is it (or not):
- clocked (did you try?)
- grounded
- also powered by a Teddy Pardo
- only using 2 ports (no other devices connected?)
The ER is upgraded with a Teddy Pardo 12/2 and Ghent Audio Gotham Starquad DC cable, supported on a Target shelf and IsoAcoustics Minipucks. No separate ground connection, as it is not required with a ground PSU. No external clock.
