Back to ack...I wonder if people get told to be careful navigating the stairs, so that the don't get too close to the speaker. Very impressive system!
Hi,
Thanks for the great pictures. I hope you don't mind if I mention a few things. Spectral recommends 12" of airspace above the preamp. You can have a little less. Your preamp could eventually develop problems do to overheating. In your case, a cooling fan should be used. Also, we would suggest that you don't put the DMA-360 on top of a subwoofer. I assume you always put your SDR-3000 in standby when not in use. If not, be sure you do!
Why didn't you biwire instead of jumpers?
While others are bickering why threads are marked sticky and what Harman Intl is doing or not, I can happily report that I am having a blast of a Friday with RR-101 and RR-113 - two all-organ HDCDs that the system can now play with no strain or obvious distortion, completely under control and full of composure, albeit the obvious lack of sheer volume. This was not possible before the crossover and structural mods. I will need a second REL Stadium III at some point to move more air.
