I suspect Preamp will be Pilium as well.
Yes, Pilium three chassis Olympus Pre and Zeus stereo amplification.
Reactions: audio42
Thanks Emile, more fascinating insights..!
I assume the size of the internal storage on the Olympus wouldn't matter wrt sound quality, its just the fact of it being there or not, in the form of a single drive of the type you identified / recommended?
Correct.
Reactions: DW101
Emile, has your testing included assessing how sound quality is affected by where the NAS is in the system and how it is powered? That is, is it optimal for the NAS to be connected to the Taiko router (as opposed to just being on the home network) and is sound quality improved by powering the NAS via the DCD?
No, however I strongly suspect this will have an effect, as adding a second DCD to your home / ISP router produces a similar effect. But we will need to allocate time to actually verify this. Of course a somewhat inconvenient side effect of placing the NAS further up stream is having to configure port forwarding etc.
It is temping to add DCDs to any device in the data stream to the Extreme/Olympus.
Roon is able to see my music NAS which is on the Taiko router network. It is a little more challenging to get my home network computers to see this NAS. Right now I am using a either Synology quickconnect and VNC for file transfer.
Thanks Emile for the updates. We may need to look into fanless NAS to place in our listerning room then. Like this one.
Well let's see if we can find more graceful solutions. Consider this update as how things stand today. I'm just trying to be completely open and forthright. We may be able to normalise the playing field entirely as the gaps that would ideally not exist are fairly small.
Of course one could argue things are more like you would expect them to be now, perhaps even normalised (assuming normal is terminology applicable to our hobby) . Priory things were more mysterious, for example adding a switch/router improving local drive playback fidelity. But now local drives are better then networked drives, unless you connect those using devices specifically designed to improve their performance, which then equalises the playing field. IMHO that means everything is now doing what it should be doing.
Reactions: DW101 and audio42
Not sure if this has been answered already: If trading from an Extreme to an Olympus plus 'Extreme Switch + Router + NIC + DC Distributor (Bundle)' is the NIC in that bundle still needed or is it the same NIC which is fitted by default to the Olympus?
No the NIC is not needed and is included with the Olympus (for absolute clarity, the NIC supplied with the Olympus is not the same NIC as supplied with the Extreme or in the bundle, the bundle is just for upgrading Extremes which are purchased prior to the NIC/Switch release. Everything produced after includes "the" NIC).
Reactions: Azjya
Yes having 2 subnets is less ideal from an ease of use perspective. It would've been best optimal sound quality could have been achieved without that separate router, but alas. For me personally however completely worth it, I'm over the moon being able to just use Tidal/Qobuz without sonic penalties.
For sure worth it to be able to use Tidal/Qobuz without sonic degradation. I'm sure all of this will be sorted out and the best application will eventually surface. However, for those of us with limited network comprehension/ understanding, ME!! When I hear port forwarding, subnets, upstream/downstream NAS placement, along with a few other terms, I want someone to shoot me in the neck with a tranquilizer dart! Again, no doubt this will all come together and many of you are so very helpful in sharing your knowledge...
From my humble experiences I also would expect this to be proven correct - I've found literally everything in the chain to benefit from increased power quality, and DCD is the best DC filtering I've experienced.
I'm not sure I understand why it would necessary or desirable to have the NAS in the listening room. If it is going to be connected via the Taiko router, the ethernet cable doing so can be 1 meter or 10 meters or 50 meters. No need to have an acoustically noisy NAS in the listening room. And having the NAS in another room will usually also make sure it is on a different electrical circuit for power.
Am I missing something?
Steve Z
Steve Z
No you’re not missing anything :)
Reactions: oldmustang
1) Haven’t tested but most likely reduced or even non existent
2) Cable length will not matter
I'm moving the discussion to the dedicated thread
@Taiko Audio
Thanks for your reply! :)
That's what I thought.
So, to summarise, in the context of Olympus + Olympus XDMI :
Internal memory or NAS , it's pretty much the same thing in terms of performance.
Regarding question 2)
I wasn't very clear about the location of the NAS.
I only mentioned the 15 metre cable.
In fact, the NAS would be placed in my network cabinet, which is in a small storeroom.
So in the middle of my network mess, i.e. another NAS, a music server, my main switch, a router, a backup NAS, USB drives, etc...
In a nutshell, a mess that isn't very audio friendly...
I don't want to place a NAS next to the HiFi. Apart from being noisy, it would be really ugly (not wife compatible)
Wouldn't that have a negative effect?
Cheers,
Thomas
Steve Z
The only issue with having it 10+ meters away is that you cant power it from the DCD at that distance unless you have 2 DCDs.
Baby steps, David. Right now all of my NAS are internally 120VAC powered. Maybe at a future date I'll explore replacing the internal AC to DC power supply in one of them with a DC jack but that won't be for some time. Much easier to use a really good Shunyata Research power cord (already have) while waiting for that day to happen.
Or, not do it at all. I am still going to compare a NAS in the other room/on another circuit plugged into the Taiko router to a local, fanless high capacity USB drive plugged into the USB port on the Taiko router and powered from an unused port on the DCD. Whichever one sounds better to me will determine what I'll be spending money on.
Steve
Reactions: John T and DW101
Steve
These will all be good tests.
I purchased a 2 bay Synology NAS which pulls just over 1A. I currently have it in my music room powered via the DCD and connected to the Taiko router. Even without any music playing I cannot hear either the drives or the fan (if it is even running; I have it configured to quiet mode). If I find that I never hear it I will leave it here. If not, I can always move it.
When your Olympus arrives, use the Extreme as a file server/NAS connected to the router. Compare to the other methods.
So, how long of a DC cable run is advisable from the DCD to a NAS?
Shorter is always better.
Got that, but I am contemplating making my NAS more remote, and it would cool if I could still use the DCD to power it. Just wondering how long would be considered too long - - "edge of failure" analysis, call it.
For someone looking for the very best in NAS for Olympus there is industrial QNAP.
It's by far best from all NASes I tested about 4 years ago.
Fanless, industrial memory ( far better than normal) few RJ45 connections, great looking as well.
It was quite expensive that time but it was introduced in 2014 so could be purchesed much cheaper those days.
