Yes, Pilium three chassis Olympus Pre and Zeus stereo amplification.I suspect Preamp will be Pilium as well.
Thanks Emile, more fascinating insights..!
I assume the size of the internal storage on the Olympus wouldn't matter wrt sound quality, its just the fact of it being there or not, in the form of a single drive of the type you identified / recommended?
Emile, has your testing included assessing how sound quality is affected by where the NAS is in the system and how it is powered? That is, is it optimal for the NAS to be connected to the Taiko router (as opposed to just being on the home network) and is sound quality improved by powering the NAS via the DCD?
No, however I strongly suspect this will have an effect, as adding a second DCD to your home / ISP router produces a similar effect. But we will need to allocate time to actually verify this. Of course a somewhat inconvenient side effect of placing the NAS further up stream is having to configure port forwarding etc.
Thanks Emile for the updates. We may need to look into fanless NAS to place in our listerning room then. Like this one.
HS-453DX | Silent but Powerful: Fanless Multimedia NAS with Hybrid Storage Structure, 10GbE connectivity, and HDMI™ 2.0 4K output
The 2018 Computex d&i Design Award-winning HS-453DX features a stylish minimalist appearance while providing maximum multimedia performance. Powered by an Intel® Celeron® J4115 quad-core processor with HDMI™ 2.0 (4K @60Hz) output, the HS-453DX allows you to directly enjoy high-quality videos on...www.qnap.com
Not sure if this has been answered already: If trading from an Extreme to an Olympus plus 'Extreme Switch + Router + NIC + DC Distributor (Bundle)' is the NIC in that bundle still needed or is it the same NIC which is fitted by default to the Olympus?
It is temping to add DCDs to any device in the data stream to the Extreme/Olympus.
Roon is able to see my music NAS which is on the Taiko router network. It is a little more challenging to get my home network computers to see this NAS. Right now I am using a either Synology quickconnect and VNC for file transfer.
From my humble experiences I also would expect this to be proven correct - I've found literally everything in the chain to benefit from increased power quality, and DCD is the best DC filtering I've experienced.No, however I strongly suspect this will have an effect, as adding a second DCD to your home / ISP router produces a similar effect. But we will need to allocate time to actually verify this. Of course a somewhat inconvenient side effect of placing the NAS further up stream is having to configure port forwarding etc.
I'm not sure I understand why it would necessary or desirable to have the NAS in the listening room. If it is going to be connected via the Taiko router, the ethernet cable doing so can be 1 meter or 10 meters or 50 meters. No need to have an acoustically noisy NAS in the listening room. And having the NAS in another room will usually also make sure it is on a different electrical circuit for power.Thanks Emile for the updates. We may need to look into fanless NAS to place in our listerning room then. Like this one.
Am I missing something?
Steve Z
1) Haven’t tested but most likely reduced or even non existent
2) Cable length will not matter
Steve Z
Baby steps, David. Right now all of my NAS are internally 120VAC powered. Maybe at a future date I'll explore replacing the internal AC to DC power supply in one of them with a DC jack but that won't be for some time. Much easier to use a really good Shunyata Research power cord (already have) while waiting for that day to happen.The only issue with having it 10+ meters away is that you cant power it from the DCD at that distance unless you have 2 DCDs.
Or, not do it at all. I am still going to compare a NAS in the other room/on another circuit plugged into the Taiko router to a local, fanless high capacity USB drive plugged into the USB port on the Taiko router and powered from an unused port on the DCD. Whichever one sounds better to me will determine what I'll be spending money on.
Steve
So, how long of a DC cable run is advisable from the DCD to a NAS?
Got that, but I am contemplating making my NAS more remote, and it would cool if I could still use the DCD to power it. Just wondering how long would be considered too long - - "edge of failure" analysis, call it.Shorter is always better.
