Ron makes, by far, the best questions among all high end audio interviews!
I agree. The others should take note. The “old guy reads from teleprompter in monotone voice” model has got to go.
Reactions: Taiko Audio
Yeah indeed, there’s a point where you just run out of expansion slots. There are 5 in total. Then you have the same “issue” we have with the Extreme that certain devices sound better in certain slots.
The current config we run here is:
Slot 1: combined for graphics and OS drive
Slot 2: network card
Slot 3: XDMI or USB
Slot 4: prefer not to use (heat)
Slot 5: USB or U.3 storage drive
@Taiko Audio Emile, could you please confirm the following (or correct if mistaken): my contemplated connection is between Olympus interface and Horizon via proprietary XDMI connection in lieu of SPDIF/AES-EBU. Under this scenario, will the analog output (your own DAC output) and Horizon XDMI output both be in the XDMI card that occupies slot 3? If so and under the aforementioned scenario, there will be no connection between Olympus and my Horizon until the Horizon is modded to have the XDMI input (because no SPDIF/AES-EBU or USB connection will be available from the Olympus side)? In the interim period, it would be just good to use the O's analog output.
XDMI is built modular with output cards, where you can only have one at a time. This has several reasons, short signal path being one of them. The proprietary Lampizator output daughter card is a single output interface, meaning you cannot have Lampizator output and analog RCA out simultaneously.
Our current portfolio of cards consists of
- analog out
- digital out (Spdif and AES-EBU)
- proprietary DAC out (Lampizator OR MSB OR Aries Cerat)
In your scenario you have 2 options:
1) install the analog output card and use its signal into your preamp until your Horizon is upgraded. This is our recommended approach.
2) use the digital output card of XDMI (Spdif or AES-EBU) into the respective input of your Horizon. This of course does not work for the time when the unit is back at the factory for the upgrade
Hope that helps!
Hello Moladiego,
I'm going to take the liberty of answering for Emile ( @Taiko Audio ) , who will correct me if necessary.
I'm going to assume that you ordered an Olympus XDMI.
The XDMI interface is a modular system consisting of two parts: a motherboard plus a daughterboard.
The motherboard is the main part of the interface and can only accommodate one daughterboard at a time.
The Olympus XDMI will be delivered with two daughter boards:
- a DAC daughterboard (analogue)
- an AES/EBU - S/PDIF daughterboard (digital)
I assume you will order an XDMI-LampizatOr daughterboard when it is available.
I also assume that you will have your Horizon modified to be XDMI compatible.
In the meantime you can use your LampizatOr Horizon via an AES/EBU connection (digital).
The other option would be to use the DAC daughterboard (analogue) directly to your preamp, if you have one.
Hope this helps,
Cheers,
Thomas
@Taiko Audio @Aries Cerat
So exciting. Getting close!
I have a Kassandra Ref II. Can you confirm when Aries Cerat XDMI solution will be available and how the retrofit will work? Will Aries Cerat provide the XDMI mother/daughterboards?
I am assuming I will listen to the Taiko DAC while I wait for Kassandra XDMI.
Any chance Taiko DAC is just as good or better? (Sorry I had to ask!) Thanks!
- analog out
Hope that helps!
Why is using USB not an option?
Reactions: Bobvin
Details on that to be worked out /announced.
As all DACs have their own unique distinct character/sound signature there’s no answer to that, do you prefer MSB, Aries Cerat, Lampizator, Totaldac etc, analogous to which wine you prefer, or perhaps you prefer a specific whiskey, or just a nice cool beer.
Just keep your analogy at wine! LOL!
That’s the intriguing question! I have Aries Cerat Ithaca dac.
I’ll try the Taiko dac Xdmi to Aries Ageto pre first and then compare to Taiko Xdmi digital AES to Ithaca dac.
I’m guessing the Xdmi interface that Stravos is building (with dedicated power supply) comes out to be the best.
But, I would honestly be thrilled if Taiko analog to Ageto pre were its equal.
- analog out
Hope that helps!
Thanks, Tsaett and Swiss Tom for your clarification. Need a further clarification: the stock Olympus comes with SPDIF-AES/EBU unless I opt to have the proprietary Horizon daughter card (which is to be provided by Taiko, not Lampizator) in lieu of the stock digital output (at no additional charge, as Emile had informed earlier), but not both cards (unless one pays for both cards)?
You’ll figure that out when you receive your Olympus :)
an answer to a question that even I seem to have figured out
FWIW my new Horizon. with native XDMI arrives this week . I will still be able to use the USB input from my Extreme until the Olympus arrives at which time I will use the Taiko XDMI digital card (although Emile knows my first experiment will be with the analogue card as I am betting that this is going to be something quite special and will influence many users to have an all in one solution). For those that go this route will the Olympus have a volume control in lieu of a preamp
As we are fortunate to be in the possession of an Ageto as-well I can tell you they play magically together. However we don’t have an Ithaca so that’s going to be up to you to try.
Reactions: oldmustang
It would ofcourse be possible to buy multiple output card options. Pricing tbd, up to @tsaett actually. You can express your desire to purchase multiple cards by contacting support@taikoaudio.com .
Volume control is on the wish list, already moved up to the to-do list even!
my question regarding the absence of a volume control and using the analogue card and go direct to amplifier is, "how will one control volume " until a volume control becomes reality on the Olympus
Thanks, Emile, for your further clarification. Please set up an individualized configuration system to deal with buyers' preference for the specific digital output that comes with Olympus prior to shipping. In my case, (1) I do not want to have the SPDIF/AES-EBU daughter card and want to have the Horizon daughter card only (you had confirmed earlier that it would be an even exchange with no additional charge); (2) desire to have the analog card preinstalled with Olympus (with the separate Horizon card included in the Olympus shipment box); and (3) ship my Horizon to Lampizator for retrofitting upon receipt of the Olympus.
Roon has a volume control.
