EMT - JSD series Carts
I tried stx 20 I wasn't crazy about how well it drove the EMT was less transparent than other step ups I've tried already the internal one of my allnic 7000 was much better. To date the one we liked the most is the Kiseki mct 2 but it is unobtainable. the EMT 6 platinum is very sensitive to adjustments such as VTA and everything else. before deciding which step up to use it with, let it work for at least 50 hours. I drive it fantastically with the ypsilon 10 L by putting a 480 Ohms resistor in parallel making it read around 260 ohms. another step up that drives it to great effect is the good tx 103. enjoy listening
You must bridge the blue 33uf tantalium caps ,they only for SFL models (resonance) then you get transparence and real good tonal balance.Screenshot_20240401-220949_Write on PDF.jpg
Reactions: MortenB
Just to support what’s being said about the JSD - Platinum being very sensitive to VTA, load etc… As mentioned above I started out with the cartridge seeing a load of around 295 ohm.
Yesterday I decided to make a small change to get the load more in the middle of EMT’s recommended load on 200 -300 ohm. Now the cartridge ‘’see’’ a load of 255 ohm, and I must say I’m a bit surprised at how much of a change it made. Before the change the treble range was a bit forward and too much, now there is coherency from top to bottom.
Time for more break-in :)
Reactions: Erik-Alexander
Giusto per supportare ciò che viene detto sul fatto che il JSD - Platinum è molto sensibile al VTA, al carico, ecc... Come accennato in precedenza, ho iniziato con la testina che vedeva un carico di circa 295 ohm.
Ieri ho deciso di fare una piccola modifica per portare il carico più al centro del carico consigliato da EMT su 200 -300 ohm. Ora la testina ''vede'' un carico di 255 ohm, e devo dire che sono un po' sorpreso da quanto cambiamento abbia apportato. Prima del cambiamento la gamma degli acuti era un po' avanzata ed eccessiva, ora c'è coerenza da cima a fondo.
E' tempo di ulteriori irruzioni:)
Buongiorno, il consiglio che vi do è di dotarvi, se non ne avete già uno, di un sistema di controllo per ridurre al minimo l'errore radiale (scegliete voi A o B) e non limitare il controllo al solo due punti nulli che ti danno le mascherine normali. Ho verificato che il corretto allineamento (io utilizzo il Wally Tractor Universal Lofgren B) ha migliorato notevolmente il suono dell'EMT. Posso chiederti quanto hai pagato per l'acquisto dell'EMT rigenerato?
Reactions: MortenB
My Italian is extremely rusty, as in non existing, but google translate helped me out. Thanks again for your advise, I much appreciate this and will try different aligments of the cartridge at some point when it’s broken in…
Regarding the price I consider myself very, very lucky.
I bought it from the first owner who actually had it rebuild twice because he damaged it. Or I should say, it was damaged by the cleaning lady the first time, and then by the owners young son the second time. So the poor guy did not want to risk damaging the cartridge again, and offered it for sale when it was returned from EMT after the second rebuild. He needs a cartridge with a solid stylus guard.
Anyway, he offered it for sale, brand ‘’new’’ after the rebuild, but for some reason no one seemed interested in it, and he lowered the price a few times. When he suddently dropped the price to DKK 10.000 equal to around 1.345 euros I had to buy it. When I met him to collect the EMT, he mentioned that he paid DKK 12.500kr or equal to 1.675 euros for the rebuild (twice)…
Reactions: Massimo66
Yes, better to have a stylus guard like this! A local guy made a batch of this stylus guard and sold them for $40 each. Expensive for what it is but does help to prevent expensive retips. I think it is easy to made if you know someone with a 3D printer.
Reactions: MortenB
Time for an update on the JSD - Platinium… It’s installed in a new (to me) Acoustical Systems - Aquilar tonearm on my Sikora and I’m still using the Lundahl 1:4 SUT mentioned earlier. I also wanted to try the Platinium on my 12” The Wand - Master Series arm, but I don’t have enough spare counter weights to balance the heavy 18g cartridge, so for now the Etna is on The Wand.
I really, really like this cartridge and SUT combination. You guys mentioned that loading is critical, and I agree. It’s actually more critical, than I expected it to be. With the 1:4 SUT I’m now using 240 ohm resistors across the secondary = the cartridge ‘’see’’ around 222. EMT recommend a load between 200 and 300 ohm. With larger resistor value where I’m at the top of the range around 300 ohm I find the top end a bit too bright.
Compared to the Lyra - Etna on The Wand - Master Series, I find the Etna a bit fuller and punchier in the midbass and sweeter in the treble. It’s loaded with 500 ohm into my Thöress - Phono Enhancer. In this combination of cartridges and arms, the EMT is slightly leaner and more transparent, especially in the midbass where I hear more details, more clarity than with the Etna. On voices the Etna is very strong, very natural, and this is an area where I initially struggled to find a sweet spot for the Platinium in my system, but the 240 ohm loading was the key opening up the sweet spot. Now voices are as natural with the Platinium, as with the Etna and there is something about the midrange on the Platinium that is so right. Again, the cartridges are in different arms, and one is running directly into the phonostage, one via a SUT, so quite a few variables are different, but that’s what I hear in my comparisons.
don´t forget you can tune the cart sound with what load resistor you choose to install
big differences between metal film, Vishay nudes and carbon film etc
Is your match correct here ? 240/(4x4) = 15 Ohm, not 222… 47k in parallell can be ingored
Or did you mean 240 Ohm in parallel on the primary side=cartridge side? That would give 222 ohm load on cartridge.
Reactions: DasguteOhr
But since Thales took over production from EMT, the EMT cartridge now has a 1/4 or 1/2 coil generator, so there's more choice in the SUT. Everyone knows that low-impedance cartridge work better on the SUT.
Halfcoil 0.5mv 12 ohms
Quartercoil 0.3mv 6 ohms
