Vision from the media player to the projector.had the Krell EVO-707 processor twice...how do u stream 4K ?
Audio from the media player to the EVO-707.
Simple…
“So”? So Wilson should have made this an option. I don’t understand why you seem to be arguing against this. I happen to agree with PS Audio and REL (as do you), that high level inputs are better when integrating a sub with existing speakers.So? As with almost everything in this subjective hobby each view has its adherents and proponents.
For plenty of people running a full range analog signal through DSP is totally anathema. I vote for not relitigating the whole DSP thing.The ultimate digital sub integration is via Trinnov, even more so now with their new subwoofer management:
Trinnov | Guidelines for Subwoofers Layouts & Optimal WaveForming&trade
Guidelines for Subwoofers Layouts & Optimal WaveForming™ Performancewww.trinnov.com
I agree. That's why I wrote 'for digital' sources . I also don't like converting an analog signal to digital; but if it's already digital, why not?For plenty of people running a full range analog signal through DSP is totally anathema. I vote for not relitigating the whole DSP thing.
Simple…
Right. I don’t use the Trinnov for 2ch music at all, only for multi-channel movies.Even with DIGITAL I wasn't too impressed when I listened to 2CH.
When I had Trinnov alt16 at the time,
but I had a completely different setup,
I'd love to try again.
For a $30K+ sub it’s unacceptable. It’s long been known that Wilson rebadages subs in their lower end line, and I suspect this is a rebadged plate amp and driver as well. They should at least rebadge an amp with high level inputs, or add their own, which is dirt cheap and simple (add ~100K resistors and connect to low level inputs).
Look- I own Wilson speakers so I do like the brand, but I’m going to call them out on a bad product when I see it.
How do you mean use both high and low level? Won’t that send the same signal x2?In reality, and with more modern systems, the clearly superior route is to connect the subwoofer(s) with XLR or RCA, and also high pass the speakers. This way you can improve the dynamics of the speakers and utilize the subwoofers to enable a more even bass response in a wider frequency range (at least up to 80-100hz).
