No, but there is a lingering effect over a period of time after Roon has run.
Does rebooting eliminate the lingering effect ( while potentially creating a new one)?
I love that lingering effectNo, but there is a lingering effect over a period of time after Roon has run.
Steve you meant 1353, not 1153. But you've come up with an interesting observation. As you know I installed the new Torus WM unit last Monday. Right out of the gate it sounded great, I was only using Roon. First 2-3 days everything sounded great. Then I noticed a diminished SQ. So I'm attributing this to break in on the Torus. I was scratching my head as to why it started off sounding so well and then not. Again I figured its something with break in. Then when I did the update Saturday Roon sounded terrible. Which wasn't just the new build but other factors too. I switched to XDMS and the system was back to sounding great again. Around Wednesday, Thursday, last week (before the update) is when I noticed Roon wasn't sounding the same as in previous weeks. Just kind of strange we both noticed this...Question for Emile, Christiaan and/or Ed:
Question: Do think it is possible when Roon instituted intensive data reporting and logging in their v1153 build they also instituted it across their entire ecosystem? That is, increased the reporting and data logging for previous Roon builds as well?
The reason I ask is because all my devices as well as my Extreme are still on the previous Roon build 1131 YET I heard a marked decrease in Roon sound quality several days ago with no other changes in my system. I did not post anything then because the Roon build 1153 installation package problem was being reported here and I didn't want to confuse the issue.
For me, Roon SQ got much worse that it had been with the new Taiko router.
After getting the Taiko router I thought Roon SQ had improved quite a bit and was neck and neck with XDMS, being somewhat different in the nuances and presentation by by no means bad. In fact I thought the new Taiko router made Roon sound the best I've ever heard.
Now however, it sounds flat, grey and grainy with a harsh top end and much worse than XDMS again. And this is still with Roon build 1131.
Thanks in advance,
Steve Z
Hi John,Steve you meant 1353, not 1153. But you've come up with an interesting observation. As you know I installed the new Torus WM unit last Monday. Right out of the gate it sounded great, I was only using Roon. First 2-3 days everything sounded great. Then I noticed a diminished SQ. So I'm attributing this to break in on the Torus. I was scratching my head as to why it started off sounding so well and then not. Again I figured its something with break in. Then when I did the update Saturday Roon sounded terrible. Which wasn't just the new build but other factors too. I switched to XDMS and the system was back to sounding great again. Around Wednesday, Thursday, last week (before the update) is when I noticed Roon wasn't sounding the same as in previous weeks. Just kind of strange we both noticed this...
That is what I was attempting to get at. 1311 was sounding very good, but as I was trying to explain I noticed a diminished SQ before the 1353...Yes weirdness...Is any of this necessary if one has not upgraded to the new version? I know @oldmustang experienced a decrease in sound quality without upgrading but I did not. Weirdness.
Quick question for Christiaan -- the procedure you outlined is for Roon build 1153, correct?
So this is the procedure to follow for upgrading Roon builds now (until Roon changes their packages again)?
Given that Emile said Roon build 1153 has the potential to sound much better than previous versions once they are done with their data logging and reporting, there will be significant advantage to updating Roon going forward.
Steve Z
Argh! I pulled them out of my a. . . er, head David. Thanks for the correction.Steve, where are you getting your build numbers? I am running 1311 (and have been for a while). The new build is 1353.
FWIW I noticed no degradation before or after installing 1353 with my Nucleus clone.I had no degradation either when I listened yesterday
