John, when you feel like trying to fix this it should be pretty straightforward. On the Extreme you need to uninstall anything related to Roon and then install RoonServer. It really shouldn’t be complicated.
Reactions: austinpop
Roon was set to launch as startup from Extreme Taskbar. When you also have XDMS installed and use it, Roon must NOT be set to start automatically. When on manual, it will enable using the toggle in the XDMS app. Christiaan changed this and restarted from the Extreme Server...I imagine this was why my SQ was messed up in Roon? I hope this helps... The stars are now aligned...Many Thanks To Christiaan...
@Kris
ISP fiber to Dreammachine Pro router - 9 or 14 or 22 meters of rj45 to Taiko router, 0.5m DAC to Taiko switch, 2 or 3M DAC to Extreme.
Thank you Emile.
this is very helpful.
isp fiber is directly connected to DMP router ? there is NO modem or anything like that on a way ?
Thank you Emile.
Correct, no modem, fiber plugs directly into the DMP.
The varying rj45 lengths is because of me sometimes changing the location of the router for experimental purposes. The in wall rj45 cable length is 7 meters, and I use 2, 7 or 15 meter rj45 (extension) cables to the router depending on its physical location.
Reactions: Kris
It looks like the key for top performance is in what you have.
I did not try very long cables between the routers.
Those were always 3- 5 m max.
will experiment with much longer runs as well.
but the real reason for top class sound is bps you use and top level room accoustics.
According to what's on my Extreme, I am running build 1311 and I haven't upgraded. That's all I know.
is there an issue with Roon if control app is 1353 and Extreme is 1311
That’s what I have as well. However I have had no desire to play Roon
I have 1353 on both my Extreme and my control devices (version 2.0xxx)
Since the update Roon/XDMS are not functioning apart from each other. When you toggle to Roon it should be highlighted in Green, no longer the case. When you are in Roon you shouldn't be able to access XDMS, no longer the case. My default setting is XDMS if you do a soft reboot it should resort to XDMS, no longer the case. I'm wondering if the conflicting nature was causing the horrible SQ. I'm in XDMS now and sounding great! But I no longer can access Roon!
I noticed this too. Very weird.
Mn
Mn
You need to get that sorted out. I got up at 4am and Christiaan got me situated. While that was occurring I was getting terrible SQ in Roon. I guess because both apps were open at the same time??
Is this the same as when you put three tonearms and cartridges on to the same record, and the phonostage goes ballistic?
just curious…
/ Jk
Are you saying Roon is now sounding the way it was before you did the upgrade?
just to be extra careful, if you have never run roon, is there any concern for xdms-only users with all this roon update mishegas?
