Hello all, new member here. Have been doing a lot of reading & there's lots of good info on here about the Furutech NCF stuff. I've swapped a couple of my outlets to the GTXD NCF versions & have been so impressed, its lead me to investigate swapping some of my power cables. The plan was to swap the one from wall to power bar & then from power bar to both DAC & phono stage (amp & pre are Naim & have Naim's own upgraded Powerline). I was previously using using some Neotech 3200 & 3001 in these areas all terminated in Furutech FI-15G IEC & FI 11/28 G males. To start I recently swapped the cord to my power bar with a DPS4.1 & FI50 NCF combo (also swapped my powerbar inlet to the 06 NCF). So I'm trying to figure out which way I should go with the DAC & phono. I was thinking to start with the FI-50 NCF on the male ends & use one of my current FI 15 G's on the IEC, if I like the gold I would then swap to the 46G's (& try a matching 50 NCF on the IEC as well). But I'm not sure what cable to go with, looks like the DPS & Alpha Nano seem to get the most praise. But from my reading, it appears they have a different sonic signature between each range & possibly even between the different awg sizes in the Alpha Nano series. Some are saying you can have too much of the DPS cable. So I'm wondering peoples thoughts & how these 4 cables compare, the 4.1, S022N, S032N & S55N & what might be the best choice for my DAC & phono? I did pick up some S022N to start with & will install after I have a few weeks run in on the DPS cable, I figure this would give me an idea of how the Alpha Nano series sounds like & then if the S032N or S55N might be a better option, I can move it elsewhere in the system to less critical/low current devices.
