I'm listening to Adele 21 right now, and frankly don't hear a lot of the complaints I've been reading about, *when you consider that it's a targeted pop recording*. It is certainly no sonic masterpiece, but it's not distorted or grossly mis-engineered. Just a targeted sound quite similar to many other recordings on the pop charts. I agree that the overall AQ could be better, even with the amount of peak limiting going on. Just don't listen to too loud and it's not too bad. Typical of most pop today. As for all those really blasting it, it's probably just not what they expected or wanted. I haven't heard the previous album yet.
Just take it for what it is and try to enjoy it. There's little you'll be able to do to 'improve' it.
--Bill
That's probably the heavy peak limiting. There are several areas where it gets darned crowded with multi-vocals and multi-instruments all fighting for time at the same maxed out level. They pushed it pretty hard on some songs, or that happened in mastering. Hard to tell.I agree with most of that, Bill. I suspect the negative reaction to the rather typically bad production is much a function of the positive reaction to the music itself. If it was a poorly engineered Justin Bieber record, we wouldn't be complaining because we wouldn't be trying to listen to it and wouldn't care. I do hear some stuff in there that sounds an awful lot like distortion to me, but one man's distortion is another man's power and impact, I suppose.
Your conclusion is seriously flawed, Frank.
You might prefer the sound of your resampled MP3 to the resampled CD rip, but only because there is less detail in it. The resampled CD rip (assuming equal quality resampling) will be far more faithful to the original than the MP3. Your perception of that difference is a red herring and (I think) what is steering you repeatedly to the wrong conclusions.
You can only compare like source in these types of evaluations. For example, the 44.1k Cd original to the resample. Forget MP3 entirely. It simply doesn't matter and is not criteria for evaluation of a signal path or gear, or anything except MP3 encoding algorithms and sample rates. If you EVER find any type of MP3 sounding superior to the original, it's only because of loss of significant musical information and the inability of your system (or ears) to resolve it.
Think about it.
--Bill
--Bill
--Bill
Except that we don't usually really listen to pop. We just sort of let it drone in the background for atmosphere...the musical equivalent of disco...ehem... club lighting. The content of this demands attention. Since it won a whole bunch of awards at the Grammies, it's not surprising it has gone under even more scrutiny. A victim of it's own success, not that the producers might care that is.
We agree again, Jack. If we could just get past that vertical imaging thing.......and yes, I suspect the producers, if they're aware of the criticism, are laughing all the way to the bank.
Tim
Correct, Bill. Just started to look at what's going on, and the answer was very straightforward: the MP3 had been brickwalled at 10kHz. Below, the spectrums were a perfect match, no obvious information loss there, but the response falls off the cliff at exactly 10kHz.You can only compare like source in these types of evaluations. For example, the 44.1k Cd original to the resample. Forget MP3 entirely. It simply doesn't matter and is not criteria for evaluation of a signal path or gear, or anything except MP3 encoding algorithms and sample rates. If you EVER find any type of MP3 sounding superior to the original, it's only because of loss of significant musical information and the inability of your system (or ears) to resolve it.
I've mentioned this before, but it possibly bears repeating: one easy, "technical" test I have for overall system performance is to put on a good true mono recording, stand centre of the speakers, and say a foot in front of the line joining the tweeters. In a reasonable system there will obviously be a phantom image smack bang in front of you. I then move sideways and see how far the illusion of that phantom image still stays directly in front of me.You also keep on using your microphone rant in a mono context when we aren't talking about mono. A mono mike won't give you a stable center image unless you split the signal in two and play them back as if there were two of them. You don't need a center channel to get a decently convincing center image out of two spaced loudspeakers so I don't see how you can even say you require a discreet soundsource and a discreet signal to simulate one.
Thanks, Rob. Yes, I've already done a solid round once before pushing LAME to its maximum capabilities, very comfortable with playing with the parameters. Was able to do it to a taxing music file and create a difference file that didn't rise above -60dB down. So there is certainly some scope for fiddling here ...It shouldn't be. There is no reason a MP3 can't go higher that that unless it was limited by the encoding used. If you are going to try experiments get yourself a decent encoder like LAME and do them from scratch. Set the parameters up yourself or use the presents.
Rob![]()
You keep talkng about mics and how they don't know stuff. Well a chisel doesn't know stuff but that doesn't stop a sculpture from making things with them.
I'll acknowledge it as well. I think these things are parlor tricks, personally. Fun, but not all that useful, but I've heard them too. and I've heard "tall" sound stage. And I've heard that vague sense of a vertical field you can get from some speakers/rooms when certain frequencies seem to divide into vertical layers with the response of the drivers. But there are several folks in this thread who are describing something well beyond that. They're describing, one more time -- a clearly differentiated vertical image; phantoms from top to bottom, imaging, like we get from left to right without the hardware to create that image.Even Bill has skirted the fact that in certain rooms he's been able to get sound to hover his listener's heads with just two channels. Simulate surround sound as well. That is height. Period.
