I think everybody has a good idea of what clarity is,
Clarity to me is when a vocal sounds like it's right in front of you floating in the room totally independant of the speakers.
Rob
Clarity to me is when a vocal sounds like it's right in front of you floating in the room totally independant of where that speakers are.
Rob![]()
Rob, How about every aspect of the recording and it increases in scale accordingly with the level of energy the performers desire.
Well it shouldn't sound forced just natural. It should also sound limitless for lack of a better word.
Rob![]()
Roger, most people instinctively know "natural"; until I heard Adele's '21' I didn't think I was going to come across such ... unnaturalness -- but that takes the cake! I still not 100% sure it can't come good, but it will be a major effort.Agree and watch that term "natural".![]()
How about when the entire sound stage does that, with the vocal being a distinct point within it?Clarity to me is when a vocal sounds like it's right in front of you floating in the room totally independant of the speakers.
Everything depending on everything, as in your description, has a *lot* to do with the ability of each individual piece of equipment to pass the signal with minimal alteration, even if the source is seriously degraded. As the quality and stabillity of each piece of gear (mostly preamp and poweramp, + cabling) improves, playing bad source just sounds like bad source, and there is no interaction by the gear passing it. You can always take a bad recording and twiddle with things from source to output, to CHANGE its characteristics. The problem with this is that you have no ruler for what is actually correct, only how does that particular piece of bad recording sound? Does it getter 'better'? Does that mean anything to the entire chain? Not one bit, usually.Bill and Roger, I can certainly vouch from my own experiences that these at times seemingly bizarre variations in outcomes from tweaking in various area and ways are part of the deal when attempting to improve the quality of playback.
My take on that is, firstly a simplistic "everything depends on everything": when a particular aspect is "fixed" or altered, then it alters the balance between all the components consisting of the system, a new equilibrium or stability will reached between the elements. And you may find that this new balance is not to your liking. I have had the experience many, many times of supposedly making something work "better", and it in fact sounded worse: many times quite a bit worse. The number of times I've have gone forward, and then retraced my steps somewhat, gone forward yet again, and it's even worse again! The number of combinations and permutations rapidly spiral out of control: it's enough to drive a sane person mad. Which is perhaps what I am, at least to some degree ...
It's one reason I have been doing this type of stuff for years; you get worn out pursuing one line of experimentation, and take a rest from the whole business. I gave it all away for about 15 years at one point ...
One thing I have gained though, is a sense or instinct for what characteristics in the sound quality, the type of "distortion" so to speak, signal that progress is being made or not. To an outsider I might appear quite stupid at times, seemingly, deliberately, making the sound more obnoxious, and aggressive. However, there is a method to the "madness", the end result after a day or so, is the final determinant of success or failure.
One key indicator for me shines through, always: what's happening to "bad" recordings that I play (apart from Adele's '21' :b ). When they get better, everything gets better.
You get the idea, I hope. Improving on a singular bad source is probably not an improvement
Yeah. I'm just trying to point him in the right direction, if possible. It may not be. I do recall long ago I had that mindset for awhile.He probably doesn't as we have been telling him the same thing for months but you have to realize that this is "the world of Frank as he knows it"
--Bill
I don't think that it's possible. For my own peace of mind, I have to just ignore him.
