Here's one track that simply sounds great with Sablon 2020 - Cosmo Vision - 24bit wav free download. World sound, percussion, vocals and lotsa harmonies.
I was using Sablon Ethernet from my switch to my server and than I decided to replace WW platinum 8 from the wall to my switch. I was surprised at how much of a discernible improvement there was in the sound. If you like the sound of Sablon ethernet cables you may want to try them to replace the Solution. I use Jorma AES/EBU and have no experience with Sablon or Black Cat.Greetings fellow Sablon-ians - I'm looking for some experience-based Sablon-related guidance please. My front-end is a Grimm MU-1 driving a Mola-Mola Tambaqui.
The Ethernet connection to the Grimm goes like this:
Modem --> Cisco/Meraki 220 Swich --> a "The Linear Solution" ethernet cable --> an Uptone Audio EtherRegen --> Sablon Ethernet cable --> Grimm MU-1
Both the Cisco Switch and the EtherRegen are powered by a Sean Jacobs DC3 power supply, with two independent +12vdc supplies.
My quesiton is... should I:
A - Invest in a Sablon AES-EBU cable in place of the Black Cat
B - Replace the Linear Solution ethernet between the Cisco and the EtherRegen with (my second) a Sablon Ethernet cable?
C - Skip it and stay put
Thanks for your thoughts and time!
Like Twinpeak,
i think this cable is a real bargain in the market : good sound, good price and excellent build quality.
This morning, with only 3 days of burning, it blow away a legato audio at 950 euros of my friend.
I finaly ordered too another’s ones for my pc and the switch( from switch to the wall).
Very good job Mark!
One day, I will test your XLR interconnect and AES.
You’re Right ! Mark is also very easy to deal with.Mark makes excellent cables
Welcome to WBF Brabus,
Mark does indeed make excellent cables and they offer extremely good value to some of the comparative cables from other well know high end brands, I speak from experience, having bought and tried cables from Stealth Audio, SR amongst others, also an easy and very straight forward experience dealing with Mark.
Hello MRIguy, are you aware of the generic ethernet cable inside your Grimm MU1? Depending on the version, it is either about 5" or 12".Greetings fellow Sablon-ians - I'm looking for some experience-based Sablon-related guidance please. My front-end is a Grimm MU-1 driving a Mola-Mola Tambaqui.
OK I'll bite! What do you feel is your most compelling model? Thanks! Kenglad you are both enjoying and thanks for taking the trouble to share your thoughts. Whilst I don’t necessarily consider this to be the most compelling model within my Sablon range, it certainly offers a well balanced performance at an attractive price point and has made a positive impact for several hundred users.
I realize this is an older thread now, but would you mind commenting on the improvements you noticed with the internal Realization cable in your MU1?Hello MRIguy, are you aware of the generic ethernet cable inside your Grimm MU1? Depending on the version, it is either about 5" or 12".
While upgrading cables going into the Grimm will certainly help, reverting back to a generic ethernet cable will hurt. So to me, replacing this internal ethernet cable is paramount. There are pics online of this conversion or you can pm me. I used an easily interchangeable Realization cable from Kubala Sosna. GTT Audio (Bill Parish) sells this conversion and makes it EZ. It made a huge difference in my Grimm sound. Maybe Mark can make this as well if you are keen on using a Sablon. It needs to be custom length.
For what it's worth, I have an EtherRegen that has current generation Sablon Ethernet cables on both the A and B sides. It's solid as a rock. Good Luck. Does your EtherRegen have the latest firmware. Early production dates of the EtherRegen really needed it for connection stability... such was the case with mine.
Hello - Good to know @MRIguy . I had done a firmware update early but it could be an issue. Working through this with Alex @ Uptone. Just wanted confirmation from Mark on the shielding. If tied to the connectors it can sometimes cause issuesFor what it's worth, I have an EtherRegen that has current generation Sablon Ethernet cables on both the A and B sides. It's solid as a rock. Good Luck. Does your EtherRegen have the latest firmware. Early models of the EtherRegen really needed it... such was the case with mine.
