LampizatOr Horizon - Tube Rolling Paradise
Status
Not open for further replies.
The rocket ship adapter is quite nice. I wouldn’t call it a flavor. It is marginal, like a cable. Grounding it is same, another incremental cleanliness. I would recommend the adapter, though. I have other good ones, but it is noticeably better. Also, I like the idea of supporting DIY of fellow WBF Horizon owners.
I can’t wait to visit Melbourne and have Ian pick me up in his LamborghinI :cool: Now that’s what I call fellow WBF Horizon owner support. :p
Ian below (thank u for working on my adapters!)
Reactions: Steve Williams
The only other kudo is that when you find that special set that checks all of the boxes, keep your mouth shut until you find the same set as back up because if you don’t two things will happen
1. The price of the tube will triple overnight
2. You waited too long and the tube is gone
Tell me about it, one day too late to the party.
haha thanks Tom:) Gestating alien eggs haha! that dampening compound is a b...h to apply and dry !
Damm it Ian!
You could have sent some instructions :p:D:D:D;)
Ok... this was a joke..
I call this the "lighthouse configuration" :rolleyes:
the new business idea "tube maglite" really cool
Steve,
I'm curious- with respect to your extra tall adapter from Ian, does it have different parts inside as compared to your shorter version, or is it the same except that you had Ian add height for a particular reason?
Mine are both the shorter version you and others have pictured.
Steve,
No . The shorter one has only a wave path resistor whereas the taller one has the Wavepath and I think a Dueland or some other resistor....so 2 resistors
The resistors are very long, thus necessitating the long tube and great height.
Thanks. I thought there was only one "ultimate" version adapter from Ian that works with both 2504 an 2004. Has he already come out with a newer, even more ultimate version? I bought two of the shorter versions and I've only had them two weeks. Things move fast here in this Lampi tube/adapter world o_O
Which “shorter version” did you buy?
With my OCD looking at the DAC from purely cosmetical perspective I would be already medicated heavily to calm down :p
My two as well as all of the ones Ian is making function fine with the G2504 and RGN 2004
Reactions: Blake
What is the actual height in inches from bottom to top on the shorter version? I see now the big difference in the pics...
My shorter version shroud specs:
Height: 90mm
Outer Diameter: 42mm
Inner Diameter: 40mm
Height: 90mm
the longer one is about twice the size
Reactions: John T
Status
