Yeppers... Makes sense.. Also move the Xfinity device away from all audio gear.It seems to be a balance.
The xfinity internal radios degrade the sound.
But turning the radios off, and adding an external access point with a LPS adds noise on its own.
Amen I'm all in and a believer!Well Bill at GTT made a video talking about my switch and the Aruba.
He has a LOT of systems in his place and he has a lot of clients with high end systems. The Switch X has been replacing some high end switches and producing really great results. So I was happy to hear all that. Bill also does a good job talking about the switch. He also mentions access points towards the end.
Yea I know have enough systems installed with the Switch X that i feel pretty confident about it now.
easy enough to try....buy a stretch of pre confectioned UTP and listen ( I haven't gotten that far yet, too busy buiding a dual Xeon machine) My current thoughts go into the direction of using a directional antenna for point to point contact between the audio AP and the control device or a good old fashioned wire link.Chris, if my WAP is located 30+ feet away from my audio gear and the rest of my networking equipment, does that adequately mitigate the RF effects from using a non-Aruba, well shielded WAP?
Put another way: are the primary WAP noise issues airborne or over the wire?
For anyone contemplating the SwitchX, the answer is it doesn't include the modules. Bill at GTT told me he prefers the Microtik modules, which should be under $30 per module. It's not a significant expense.Does the switch purchase include the SFP modules, or do we need to source those ourselves?
Both possibly. In your case the access point should be far enough away it should be OK from any affects induced thru the air. Really sensitive high gain preamps + poorly shielded interconnects + wide band inputs with high impeadance like single ended could be a issue. BUT the wifi would most likely be the least of the issues as it would also pick up TONS of other stuff in the enviroment like light dimmers, AZ radio stations, etc,. Tube based phono stages, MM Carts might be issue for example.Chris, if my WAP is located 30+ feet away from my audio gear and the rest of my networking equipment, does that adequately mitigate the RF effects from using a non-Aruba, well shielded WAP?
yeah, wired is probably preferrable...somehow I managed to end up with three dedicated ducts for power to my system yet not a single one for a control wire in our new home....I'll suck it up and make do with a loose wire.....Hmmm... A directional antenna like a Yagi would focus the wifi RF to a cone aera, but, it also adds a lot of gain directing a lot more power in just one tight beam. This would be fine, but, access point power would need to be reduced by at least the gain of the antenna. Like 6db. ALso keep in mind you will need 3 of these antennas. Its 3x3 MIMO so 3 antennas. the 3x3 is important too as it changes the RF stream and a 2 or 1 antenna system is much worse for a clean connection. The 3x3 requires much less retransmissions..
I guess ideally... Placing the access point as close as possible to the ipad and then vastly reducing the power on the access point would produce the best solution. Tricky to do tho. But if there was a ethernet cable by the couch/chair/table right at the listening spot, that would do it.. Hmmm.. I need to make sure in the future people prewire to that location.
WIRED is ALWAYS the best way to hook things up. Avoiding wifi is always best. But..yeah, wired is probably preferrable...somehow I managed to end up with three dedicated ducts for power to my system yet not a single one for a control wire in our new home....I'll suck it up and make do with a loose wire.....
No buts...WIRED is ALWAYS the best way to hook things up. Avoiding wifi is always best. But..
Sure, for convenience, but not sonically.In some cases wifi is better
Matt
When you follow the development of the upcoming Taiko router also sonically.Sure, for convenience, but not sonically.
