The mesh 274b sounded better, top quartile of the @20 rectifiers I have tried.
I run Sophia 274B mesh in mine which was definitely more detailed than the JAN RCA 5R4GY. I love my Mazdas in my amp... Preamp actually. Very good in the B4 (12AU7). The Sylv 12BH7 black oval plates are a bit better. But it is true what Lampi says... The outputs do not make a big impact on the sound.Received my Baltic 4 on Thursday, so about 75 hours in.
Using my my EML in place of the stock rectifier, and have tried various combinations of the stock tubes (6SN7 = Linai; 12HB7 = Psvane) and my NOS valves from the Baltic 3 (Melz, KenRad, Sylvania for 6SN7 and Mazda, RCA, Telefunken for the 12AU7). Thus far, I gotta say the EML rectifier + the stock Chinese tubes makes for a very "pleasant" combination with the right amount of punch. Admittedly, it's not the final word on detail, but the stock tubes on the B4 sound much better than the shipped set I had on the Baltic 3 (Blue "boys" + Russian Mullards). And the B4 sounds better (to me) with the Chinese tubes than with any of the NOS combos I've tried--thus far. Obviously, as Sablon mentions above, it's a challenging process of trying to find the right combination of NOS tubes that harmonize the sound for the DAC alone as well as in the context of an entire audio system.
Question: Are there any NOS tubes that are recommended for the B3 that won't work because of any changes Lampi made to the B4? I haven't yet tried my Tungsram E80cc. Has anyone swapped in E80cc tubes for the 12BH7s? Thanks all!
Another good tip! Thanks MarkThe past several months have seen me try about a dozen 4 volt rectifiers from ww2 era or older. There are some gems there for not much money - the Valvo rgn1064 / az1 mesh globe is one of the best rectifiers I have heard in Baltic, irrespective of cost. You could try combining that with say rca 6f8g / Sylvania 7n7 and Tungsram ecc40 for a great combination. All will need suitable adapters though.
According to Lukasz Fikus, every (modern) Lampi DAC can be used with every 5 Volt recti, iIrc.Can the B4 run 5AR4 rectifiers without any mods? Would it be benificial?
You're welcome.Thank you.
I went with a friend to buy a Lampi from a seller. Well... He has quite the collection of gear and tubes. He was extolling the virtues of running. 5AR4 over others. I'm ruling a Sophia 274B mesh now. I was just curious. He is in love with the Mullard/Japanese ones and they are not Uber expensive.You're welcome.
Which 5AR4 tube do you have in mind?
As a follow-up,: what I'm finding in all the tube rolling is that the EML 274b is an excellent rectifier but should probably not be paired with 12BH7 tubes--at least in my system. The The EML is a very forward and detailed tube. That, in conjunction with the extra voltage supplied by the 12BH7s and the presentation was was too dynamic and punchy. I tried other rectifiers but with little success, as the soundstage completely flattened. In general, something didn't sound right with the B4, even I rolled in other 12BH7 tubes (RCA and Sylvania NOS) in place of the stock Psvane.There seemed to be some glare associated with the EML 274b, so I swapped back in the factory Shuguang rectifier. Hence, going with all the stock Chinese-made tubes at the moment. I'l need to let the rectifier burn in, but definitely much smoother than the EML, albeit with loss of soundstage. I've got a Sophia Aqua 274 on order as well as some NOS Sylvania 12BH7s. so we'll see where that get us.
@Agent86 - if you like the EML274b, you will love the valvo globe mesh az1/rgn1064. This is where I started my journey into the pre ww2 4 volt rectifiers and still find it hard to beat on Baltic.
Electrically, these models are identical but have different socket formats. I would recommend the rgn1064 as it is the earlier of the two and suggest you look out for the wide silver mesh iteration with vertical support rod between the two plates.
