Sorry what are you looking for? If it's how do I like the cartridge, it's fantastic. My #1 cartridge now. Great resolution, body, extension, does it all...Hello! no news?
I upgraded my HD Pre about a year or two ago. I also added the input balancing transformers for my dCS Vivaldi DAC. Both were nice improvements on a already fantastic preamp.I will soon upgrade my Nagra HD pre ( I got mine in October 2018, a few months before power supply upgrade). Did you upgrade your pre, or did you buy one with the upgrade?
It's real. You won't regret it (other than being apart from it for a week or two!)Thank you! I was hesitating as I have to sent it to Switzerland, but if its a real improvement I will do it
I haven't heard the CH Precision, but I would suspect that as well, certainly something to listen for in a demo. With my Classic Phono, I have been able to nudge around the sound some with tube choices. It came stock with tightly matched Genelex tubes. Which are quite good for the money. I have also tried Telefunkens (a little to much sparkle for me), Amperex (love these great blend of a touch of sweetness, but very linear and excellent extremes) and now I have Mullards in, which seem to be the lowest in noise, but a touch more sweet than the Amperex-this seems a good match with the Nagra cartridge. In my HD Pre, it came from the factory with NOS Mullards, but I have the Amperex tubes in it now which I like best.About pre phono, your Nagra Classic is a tube preamp, as the HD pre phono will be. It is probably a better fit with the high resolution of the cartridge than a CH Precision , which might be too " neutral" . Is it your feeling too?
Yes, I have settled on 180. But like you I could live with a higher or lower setting. I am going to revisit loading soon, I guess I have about 50 hours on this cartridge now. The sheer amount of resolution, portrayed so naturally, I just love. While super hi Rez, it's relaxed, easy, pulls me in...
