Compression drivers / Horn FR graphs ( Vitavox S2 )
Peter is this the one David and Tang are using?
Very nice comparison this frenchmen did .
This unit measures very good , quit surprising 700 Hz - 6 khz Flat :cool:
I dont know how your speaker measures but i suppose its something similar as the Vitavox S2 / Stereolab SL 600 combo regarding High Freq extension , so may be it wouldn t be a bad idea to add a high freq unit
Reactions: mtemur
I think if i ever was going to do something with Horns it ll be a 2 way system with either the TAD 4001 or TAD 2002 compression drivers , well made with extremely nice flat FR up to 20 khz
The TD-4001 is of the rear compression design, which eliminates the resonance and phase distortion produced by a surround. It also eliminates cavity resonance interference, achieving very flat frequency response, extremely natural sound and superb definition. A phasing plug helps smooth the response of extra high frequencies.
Reactions: MRJAZZ
For example a + - 102 db spec View attachment 107798View attachment 107799
Andro, I do not know the compression driver or horn that David and Tang have in their speakers. Contact ddk and ask.
my speakers go to about 15,000 Hz. I have not measured them in the room. I do not want to add a high frequency tweeter for extension. I have spoken to people who feel strongly that that would ruin the design of my speaker. They’re just the way I want them. If I had heard issues I would not have bought them.
The 4001 lowest crossover point is 600 Hz and the 2002 lowest crossover point is 800 Hz. My crossover is at 500. I would think 500 is better in a two way design, asking the woofer not to go as high. More range for the human voice. Just a guess. Perhaps it doesn’t make such a difference, but I would think for a two-way design, the crossover point would be critical.
what do you think?
Reactions: the sound of Tao
Fair enough .
At 15000 hz they are 10 - 13 db down from your midrange SPL (assuming your horn / compression driver combo will produce something similar as the first graph)
Which can make it sound a bit dull on certain recordings .
Reactions: jeff1225
Regarding the Vitavox S2, I am using two pair in my 6 way horn system. The first is 600Hz - 1kHz in a 250Hx tractrix, second is from 3.2kHz and it rolls off at 12kHz in a 400Hz tractrix. 12kHz and up is handled by a RAAL Lazy Ribbon for which I am considering horn loading.
I think if i ever was going to do something with Horns it ll be a 2 way system with either...
If you want the best that horns can offer, I would recommend an active system with at least 4 ways. Two way will not cut it...
Reactions: carolus
I’m presuming the ‘fourth way’ being active sub base ?
Sort of. Enough bass channels to sort out the room frequency response below its Schroder frequency then horn load everything from there on up. For instance, I have three horn loaded channels and the RAAL ribbon above circa 110Hz and that is enough to keep the horns operating optimally (remember a horn is at most a three octave device*, preferably two), but for my room even with a lot of bass absorption (RT60 is 0.2s down to 60Hz!) I need two bass channels below 100Hz to beat the room modes.
*waveguides may operate over a wider frequency range than a true horn
What i find strange is that TAD doesn t supply FR graphs on the website .
Any unit manufacturer usually does that, same goes for Vitavox
Below is a response of a TD 4003 i found on the net , first of all its not flat up to 20 khz , its breaking up after 9 khz
Use a dayton h 812 horn with b&c de 250 driver impressive sound for 1"driver crossover point 800hz really flat to 18khzFR-DE250.jpg
Need damping on the back side (blutak)then it is really smooth. From 80hz -1khz use a tone tubby 12" alnico 100db/1 watt. Under 80hz a ripol bass . Ready for party sounds really good
Not sure I agree with you. It is VERY difficult to get good coherence in a multi-way speaker setup and most fail to some degree or another. There are some examples of two or maybe 3-way horns that sound very good and can give the dynamic expression that people go to horns for.
There are some legendary successful examples:
JBL Hartsfield (in 2 or 3 way config)
Vitavox CN191
JBL Paragon (3 way)
Klipschorn and La Scala (3 ways)
Altec VOTT various forms that are 2 ways
Klangfilm Bionors
etc.
Use a dayton h 812 horn with b&c de 250 driver impressive sound for 1"driver crossover point 800hz really flat to 18khzView attachment 107941
Don't like the sound of plastic diaphragm compression drivers. Ring radiators are better but a good metal dome design to me still sounds the most realistic.
Reactions: mtemur
Everyone has their preferences, you don't have to copy them. I just wanted to show that there are other ways than Tad. too expensive for me for what they deliver.
what do you think?
Hello Peter
I think it is driver/woofer dependent. You can always generalize but there will always be exceptions that will work quite well above 500 Hz in a 2 way design.
Rob :)
Thats were measuring comes in .
Just stacking up drivers and adjusting everything by ear is bound to fail.
Thats my opinion ;)
The horn sizes themselves provide a barrier to getting a reasonable time alignment on the speaker...not talking actual time coherence but something that sounds reasonably coherent...
And what about Freq response ?
Unless you conceive yourself as having " Golden ears " lol , measuring FR is far more accurate then your ears.
what do you think?
I think in every loudspeaker design, but, especially, in a two-way design, the crossover point is critical.
Not that I went to loudspeaker design school over the weekend, but I would prefer a 500Hz crossover point over an 800Hz crossover point on the ground that the 800Hz crossover is breaking the midrange frequency range into two big pieces. 500Hz is more in the lower midrange.
