New DartZeel Owner
BR549
56
123
120
63
I am a new DartZeel owner, adding the 468s and matching pre (Mk II) just this afternoon to the system. I’ve read virtually every thread on this forum and had worked myself into a frenzy with questions, etc., but once I turned them on, all was well and the questions are no longer as pressing. Between that and the Horizon I added a couple of weeks ago, I am blown away. Color me a happy camper and thanks for all of the wisdom you all have shared on here over the last several years.
Congrats Jim!
Congrats Jim for your DREAM system ! I'm sure it will bring you long hours of listening pleasure
Beware the remote control … that thing will move the volume fast.
Congrats! I was just speaking with someone in the industry (well regarded high end manufacturer) who heard the Dartzeel ref preamp and 468 monos, and was very very impressed.
Reactions: Pokey77
Congratulations, BR549! I wish you many years of musical bliss!
Well, after letting them break in for a few months, I finally got the 50 ohm cable from Evolution Acoustics. If you are considering a pair of these, I highly recommend the “Zeel” connection to the Dartz pre - changed the entire presentation as compared to an XLR connection (although I had mid tier AudioQuest XLRs just due to the expense of the long run). I likely don’t have 500 hours on the amps (which is what I understand I should anticipate for break in) and I don’t have much time at all on the cable, but it sounds so good. The hits just keep coming.
Congratulations and cheers to an amazing system!
Installing the Thixar Amp Stands under the 468s tomorrow. I will frankly be surprised if they make an audible difference, but they just look so good.
Well, that's why one has to try these things. The Thixars had a significant audible impact - while it's difficult to quantify these things, it was the last step to really really opening up the sound. I suspect it is a little bit of the Evolution Acoustics 50 ohm cables and the amps/preamp themselves getting finally broken in, but the activation energy for the equation was the Thixars. Of course, the monos weigh too much to just try an A/B at will, but I was quite pleased with the SQ uplift (and I bought them for looks only!). I'm not sure it was exactly a sound quality change, as much as a presentation change, but I like it ... a lot. Try it - YMMV.
Reactions: ICUToo
No photo evidence — it never happened ;)
Here’s a crappy iphone photo! I have not posted photos on this site before, so I apologize if it’s huge, improperly oriented, etc. Even without the sound, the stands just look so good under the amps, they’re hard to resist.
Nice. I have a model 1 108 and could not be happier. Well, maybe a second model 1 since my speakers are biampable.
Reactions: Zeotrope
would you consider posting your system in the Members Gallery?
Right. I only press and release, never hold the vol button down.
Updated ALTAIRA ground connection for the 18NS preamp with custom ring terminal from Shunyata:
@Zeotrope - not quite the topic of this thread, but thanks for that photo. Note that the NHB18NS (or mine anyway) allows a banana plug into the ground lug on both sides of the mono. I used that to chassis ground to material audible effect. Perhaps I did it wrong, but it worked for me and seemed to be designed for that purpose. Otherwise, I would have gone the same route you went.
