Clearly, IMO the tube selections made by members boils down to same factors'Hi,
It depends on the group of tubes you use. Right now i don't have a Tak rectifier. From what I have read that pushes the KT 170s very well and i believe Steve Williams uses the Tungsol TS JAN CTL 6SN7 GT and i don’t have that tube either.
So I really can’t say.
But I will do a shoot out between these two groups eventually.
Frankie, 6N1P, Bendix 6384
Tak, TS JAN CTL 6SN7 GT, Kt 170s.
Right now I’d say the type of music you play and your taste will determine which is best.
One's system
one's ears
availability of desired tubes (if I find a tube I like in my system I only buy it if I can also buy backups) SAs for the Tak 274B in my system it was an ear opener and permanent part of my tube set
