My replacement bracket has exact same issue as original bracket - disappointed.could anyone who has received and installed their new bracket comment on their findings as to resolution of issues
That's because it isn't a bracket (mechanical fit) issue. However, if your (old) bracket didn't line up correctly it could possibly cause a different -- physical contact -- issue.My replacement bracket has exact same issue as original bracket - disappointed.
Yes.That's because it isn't a bracket (mechanical fit) issue. However, if your (old) bracket didn't line up correctly it could possibly cause a different -- physical contact -- issue.
Steve Z
I have the same question.I still wonder why some have had no issues with the new network card + bracket? If it’s a temperature issue, wouldn’t their machines have also disconnected the card?
Share for all :In the spirit of this track, I recommend also listening to ((( O ))). I know, this is impossible to search for, but it will help if you know one of the song titles, for instance, "Infintro", which is track one of the album ((( 1 ))). Sorry, I am not making up these names and it does not help infintro is spelled without an i. It's like she does this on purpose...Anyway, well worth listening to, I promise!
Ben Lau of Volent HK was able to run one of the several cards in hand with the bracket screw not installed (and the Extreme chassis top lid NOT removed) continuously for several days without any problem.
Dear Emile :
Is that a pure firmwire issue?
Or is it possible that there are irregularities of the components on some of the cards?
You can see this in the Mini Player (bottom bar) when the file is playing.Where can you see if the files are WAV or FLAC files. I've never paid any attention other than if they were 44.1 or DSD files.
Wow. Cool. Thx Christiaan. I am fascinated since playing files with the new Switch and even with the old card, how amazing they sound vs the streaming. I used to try and play files occasionally but I personally did not feel that they sounded so amazing (maybe they did and it was just me) that made me want to listen to only files as I loved the streaming selection of music. Now I have a dilemma. I think the dilemma will lessen when we get the future enhancements in place.You can see this in the Mini Player (bottom bar) when the file is playing.
For instance, Apple Lossless below:
AIFF or WAV:
FLAC:
Will make a note to think about adding this to the folder view.
It's Metric M4. But you should also be able to find a compatible non-metric wrench. According to Google, "4mm = 5/32 inch (= a bit over 1/8 inch) "No, it’s definitely metric. I believe M5 but I will double check…
Hi Bob, I'd say there are worse dilemmas to haveWow. Cool. Thx Christiaan. I am fascinated since playing files with the new Switch and even with the old card, how amazing they sound vs the streaming. I used to try and play files occasionally but I personally did not feel that they sounded so amazing (maybe they did and it was just me) that made me want to listen to only files as I loved the streaming selection of music. Now I have a dilemma. I think the dilemma will lessen when we get the future enhancements in place.
I don't think I will ever want to do demos with streaming for now vs files. The DSD files sound CRAZY GOOD.
And this is why I never stream!Wow. Cool. Thx Christiaan. I am fascinated since playing files with the new Switch and even with the old card, how amazing they sound vs the streaming. I used to try and play files occasionally but I personally did not feel that they sounded so amazing (maybe they did and it was just me) that made me want to listen to only files as I loved the streaming selection of music. Now I have a dilemma. I think the dilemma will lessen when we get the future enhancements in place.
Except you have users who have not had an issue with the old bracket which is screwed in, so there is no gap. Maybe their room and Extreme are just well cooled?Low amount of internal storage, airconditioned room, no screw with the old bracket leaves a gap between chassis and bracket, lot’s of clearance around the Extreme, etc.
Bummer - so two issues stacked, first some non-aligned brackets causing intermittent errors and then temperature guard that triggers too early.
Will run top-less Extreme until fix arrives ;-)
SQ is still awesome.
