My LPS is JCAT Optimo which has Speakon Connectors to the LPS. The wire I'm using is 16awg copper...My plan is to go BPS in the future and all of this will end...EDIT: I could modify JCATS DC Cables. Supposedly they are 2.5MM however I have my doubts...I talked with Bob @Rhapsody he's using JCATS DC cable to the switch. He said its not falling out but not as snug as it should be. If the switch is 2.5MM and JCATS DC cable is 2.5MM something is not jiving...hi John,
Are you making your own DC cable? If so, what type of cable are you using to solder the dc barrel?
Thanks
