There are two SFP+ ports that can take either SFP modules (such as FTP or Fiber connector modules) or indeed DAC cables (that connect in the slots directly). In most use cases, a combination of RJ45 and DAC will be used, with RJ45 on the "source" or "upstream" end, coming from the Router.My switch is coming shortly so I will see for myself, but it appears that there are TWO DAC cable ports from the recent comments vs. what the drawing on the Taiko Switch page shows. Is this the case?
The Extreme must be powered off for the removal/installation of any internal hardware components. After that, it can be switched back on and then the installation script can be run.
I could hear a difference (maybe because I am using only headphones). With the DAC cable installed nearer to the power DC inlet, the sound is smoother, more organic, and coherent. When I had it the other way round, it was thinner and sounded hollow.
I prefer it with the DAC cable installed nearer to the power DC inlet.
As it is winter, I would like to add that grounding oneself by touching the chassis of the Extreme for a few seconds while it is connected to the mains to discharge oneself will be helpful.
That is a good suggestion.
This has been added to the documents, along with various other helpful bits of info. As always, the latest versions can be found on the Taiko website at the bottom of the product pages.That is a good suggestion.
I would caution against swiffering or otherwise swiping/cleaning/vacuuming the insides as these actions may indeed add static charges. Please don't worry about accumulated dust on the inside. For the most important parts, the cooling takes place on the Extreme's outside via massive over-specified heatsinks.Btw. for the ones that have more dust built up (due to carpets and so forth), is there a best practice recommend by Taiko for getting the dust of the Extreme’s valuable „intestines“ while we already have removed the top plate?
I was thinking about a Swiffer anti-dust magnet fluffy thing (which I regularly use on the outside for my components), but I‘m not sure if it‘s not potentially causing a static charge?
Maybe if applied very slowly and then do the above described static discharge / grounding routine, before turning the Extreme back on again?
Any recommendations are greatly appreciated to safely take care of our baby!![]()
Then in fact the drawing that only shows one output port on the Switch page is not accurate. No big deal, looking at the diagram always made me think there was one input port and one output port.There are two SFP+ ports that can take either SFP modules (such as FTP or Fiber connector modules) or indeed DAC cables (that connect in the slots directly). In most use cases, a combination of RJ45 and DAC will be used, with RJ45 on the "source" or "upstream" end, coming from the Router.
For sure. Next time we do a larger volume presale we’ll allocate an extra 2-3 weeks for assembly/preparation and perhaps smaller batches. This has been, and still is a little crazy![]()
The Switch has two identical ports, both SPF+ and you can insert either SFP adapter modules for RJ45 or Fiber, or DAC cables directly. The diagram shows the most common use case.Then in fact the drawing that only shows one output port on the Switch page is not accurate. No big deal, looking at the diagram always made me think there was one input port and one output port.
OR are there only two ports and they are generic as you say so that you can use either port for input or for output? But it seems using the port closer to the power port for output sounds better?
Correct. You can also connect to the new Ethernet Card but do note that it will have a different IP Address which affects XDMS/Roon remote control and VNC access.Christian please confirm if this is correct.
1.- We install the Network card.
2.- We turn on Extreme, BUT WITH THE OLD NETWORK CONNECTION, IE WITH AN ETHERNET CABLE TO AN RJ45 PORT ON THE EXTREME MOTHERBOARD.
A restart is automatically prompted by the script.3.- Run the Script connecting with VNC
4.- Restart Extreme
Correct.5.- Remove the RJ45 cable from the RJ45 port of Extreme and connect the DAC cable to Extreme and the Taiko Switch.
6.- We connect Switch Taiko and our Router with Ethernet cable
7.- We pray fervently
8.- We load XDMS
If the network card works even if you don’t run the script why do you have to first connect to the Extreme using the MOBO ethernet port?
More convenient for those who don’t know how to update their VNC IP address.
Yes.I guess I will know once I do this but won’t the IP address change once you do start using the card?
