State-of-the-Art Recordings of Classical Works (SACDs)
Yuen A.
870
737
228
SACD - 60597
If there ever such a thing as a perfect performance/recording, this is one such! The sound is very close to that of a live, resonant experience. The sound is immersive, on occasions, heartbreaking, totally transparent and pure. The resonance, timbre, texture and tone of all the instruments are spot-on. However, to me, this new level of sound performance is only possible with the inclusion of the Ansuz Acoustic D-TC Supreme and D--TC2 signal cables, D-TC PowerBox (grounding), D-TC resonance control footers, Shunyata Sigma power cables, EMM Labs SACD transport and DV2 DAC, Magico M2, Magico Q-Sub 15, and Critical Mass Systems Maxxum rack and amp. stand.
TY; just found it on ePay.
Tchaikovsky: The Nutcracker, Op. 71, Bergen Philharmonic Orchestra, Neeme Järvi. Chandos CHSA 5144 (SACD)
A truly realistic recording! The soundstage is huge and deep. The hall acoustics were very well captured. There is plenty of space and air between instruments and all the musical instruments here sounded real. Fortissimos sounded awesome. Play at a loud volume.
MIKHAIL GLINKA - Overture to Ruslan & Ludmilla
MIKHAIL IPPOLITOV-IVANOV - Procession of the Sardar from Caucasian Sketches
SERGE PROKOFIEV - March from The Love for Three Oranges
ALEXANDER BORODIN - Polovtsian Dances
NIKOLAI RIMSKY-KORSAKOV - Capriccio espagnol
ANATOL LIADOV - The Enchanted Lake; The Music Box
ARAM KHACHATURIAN - Love Theme from Spartacus
PIOTYR ILYICH TCHAIKOVSKY - Russian Dance (Nutcracker); Hungarian Dance (Swan Lake)
MODEST MUSSORGSKY - Polonaise from Boris Godunov
Telarc SACD 60657
Another state-of-the art sound from Telarc. The dynamics are close to that of a live performance, the soundstage is immense, transparent, atmospheric and well defined, the strings are life-like, the brass has the brassiness, the woodwinds are sparkling, and the bass drum sounded resonant and like the real thing in a concert hall setting! The performances are first-rate, intensive, precise, refine, and with excellent control.
Great to have your contributions. Are you listening to the stereo versions or multichannel or both? Thanks, Larry
Hi and thank you! I am listening to the stereo layer. By the way, I forgot to mentioned that I am currently using a Constellation Audio Centaur Stereo amplifier.
Telarc SACD 60657
I own all the three recordings you listed in your previous posts. Of those three I (only) play Russian nights regurlarly, in particular because I love the piece ‘enchanted lake’ of Liadov. Very melodic and - indeed - enchanting. Most of these old(er) Telarc recordings sound very fine indeed. The only reservation I have with these Telarc recordings is that the (massed) string tone (to my ears anyway) is most of time somewhat thin/edgy. Good to read that they sound in your set up “life-like”.
Hi, Yes, indeed, the massed strings sounded lifelike via my sound system. Replace the weak components in the sound system that are contributing to that edgy sound. Lowering the noise floor of your sound system by using state-of-the-art signal and power cables, power conditioner, resonance control footers and racks will greatly eliminate edgy sound.
Well, I believe that I may say that I own two top notch audio systems with inter alia (Kondo) tube amplification. Both with an extremely low noise floor due to the fact that I am using the top of line Tripoint ‘grounding’ stations and grounding cables. The result is in both audio set up the same (please do not get me wrong: I really like most of the Telarc classical recordings)
Sergei PROKOFIEV (1891-1953)
Symphony No. 1 “Classical”, in D major, Op. 25 Symphony No. 2, in D minor, Op. 40 Symphony No. 3, in C minor, Op. 44 Bergen Philharmonic Orchestra/Andrew Litton BIS SACD 2174
Listen to the symphony no. 2 and 3. Perfect sound forever! These two pieces are truly of demonstration quality. Dynamics (fortissimos) are awesome, shocking and scary! (Play loud) All the instruments sounded alive, vivid and true to its timbre. Bass drum sounded tight, detailed and has shocking impact. The performances are also state-of-the-art.
Reactions: A-Line and Campo007
SACD - 60597
Hi! It's great seeing this post, just as I was looking for some music recommendations. What do You consider the most touching records in Your collection? Do You have any recommendations for an occasional classical music listener? Thanks!
I had a listen to the whole album this morning and was very good! Thanks for these recommendations
Reactions: Yuen A.
Hi,
This album of light classical music may interest you:
Edvard GRIEG Incidental Music to Peer Gynt, Op 23 Piano Concerto in A minor, Op 16 Lise Davidsen, Ann-Helen Moen, Victoria Nava (sopranos), Johannes Weisser (baritone), Håkon Høgemo (Hardanger Fiddle), Jean-Efflam Bavouzet (piano) Bergen Pikekor; Bergen Guttekor; Edvard Grieg Ungdomskor; Edvard Grieg Kor; Bergen Philharmonic Choir and Orchestra/Edward Gardner (CHANDOS CHSA 5190 SACD)
Top-notch performances and recordings. Yearningly beautiful, and heartfelt, spot-on instrumental texture/timbre, amazing true-to-life dynamics (e.g. the whacking of the timpani on track 4), full, rich and awesome low bass, lifelike transients from the percussion instruments, lushness from the strings and the sound-scape beautifully lit in a gorgeous reverberant hall.
Hi,
What an amazing recommendation. That was a rollercoaster of emotions, and you were right - that timpani at the 4th track was indeed quite shocking, and reminded me of my love for drums of any kind. Have you got any drum-focused favourites when it comes to records? Would love to take a listen to those as well.
Tarik O'Regan Acallam na Senórach / An Irish Colloquy (National Chamber Choir of Ireland; guitar: Stewart French; Paul Hillier) harmonia mundi usa SACD 807486
A captivating and beguiling work. The choir is set for 16 voices, accompanied by the guitar and drum roll that open the "Prologue" (Track 1). The drum, guitar and voices sounded real and tangible! A great test disc! Via my sound system, the ambient retrieval, harmonics, textures, tonality, dynamics, transients/decay were spot-on. Very immersive - Play loud.
I'm always playing loud :)
In the meantime, I recommend you the La Folia De La Spagna by Gregorio Paniagua. An incredible recording with dynamics and textures that are out of this world.
Also, watch your volume, as there are some deafening sounds in the album.
2348b2164980b523f09b253b2207
With apologies if this is considered inappropriate, I am looking to sell a collection of classical SACDs in bulk. I have just sold the house where that collection and a small MCH system were used and I am in the process of emptying it out.
I am scanning them now to offer a listing but that's not yet ready. However, if you are interested in a collection of 600-1000 (estimated) SACDs (>90% classical), please contact me by PM. Thanks.
Kal, suddenly my computer won't let me send PMs (or change my signature, either!) Could you pls PM me with your e-mail address so we can discuss this treasure?
Reactions: Yuen A.
