I went from an analysis plus oval 2 power cord on the Super 3 to Furutech DPS 4.1 with FI 50 NCF plugs and it was quite a big difference
I have 4 Super3. All with the Purple fuse and the inlet upgrade. I use the Silver 2 cables.Have you experimented with different ac power cords on the Farad? Makes a difference?
Thanks. Interesting area to investigate. If the Farad is excellent, it is worth investing further in upgrades. Specially if the rest of the system is sorted out well. I will test it with Tubulus Concentus v2 power cord. I will say this power cord represent great value, have use it on both amp and Dac with success.I have 4 Super3. All with the Purple fuse and the inlet upgrade. I use the Silver 2 cables.
I have not gone up to the Dragon level but have tried different power cords. A stock one, the Farads own and the Vertere RedLine. Yes, it’s a noticeable difference in sound. The Vertere is for me the clear winner of the three.
Are you located within EU?Hi all,
I read a lot about LPS from Sean Jacobs DC-03 and DC-04 and was wondering if anyone had the opportunity to compare them to the Farad S3.
Do they always provide a clearly audible improvement or are they strictly related to audio gear?
I’m planning to add an LPS just for my router (Fritzbox) and these expensive tools makes me think if the investment is really appropriate for a simple router like that. Any suggestions?
This might be an alternative to test, only know from others who used on switch's and router's. A cheaper option.Hi all,
www.beatechnik.com
Power supplies… Me to but in France. I have a couple of friends whom have bought electrical equipment from outside EU and not CE Certificated. I am not sure if you are sensible for that but important to know. At least I think so.Yes I am… Italy.
If you read and scroll down the customer reviews in the link under there is described improvements on Farad used on "normal" routers.I’m planning a room refurbishment with 5 dedicated lines (and a dedicated panel). i already use AQ Dragon power cords and a PS Audio P20 regenerator so I’m very sensitive about power in general.
just wondering if non-audio gear might need the same expensive attention, in my case I have only (out of P20 regen) a router. I will hook it to a Furutech eP609E power distributor but I want to avoid in addiction SMPS.
is Farad or other LPS overkill for the purpose? That’s my doubt.
Thanks
Hi all,
I agree that the FRITZ!Box is a solid and good device. But digital devices benefit a lot from low ripple noise. Especially linear power supplies offer that.But a Fritzbox is great peice of gear, and does not normally need a low noise power supply.
I might be out cycling here but if the Fritzbox is a good switch maybe an alternative would be to go for a fibre converter instead of a additional switch and have the converter and the Fritzbox powered by one dual power supply ….I’m planning a room refurbishment with 5 dedicated lines (and a dedicated panel). i already use AQ Dragon power cords and a PS Audio P20 regenerator so I’m very sensitive about power in general.
Thanks
Software settings also have an impact on the sound. So it makes sense to disable the strong WLAN transmitters in the router and outsource them to a repeater. If you are interested, I have written something here: FRITZ!Box audiophile setup.
Are these cables better than Farad level 2 DC cables?I found adding a high quality DC power cable to be equally profound to adding a quality AC power cord or the addition of the LPS itself. The stock DC cable from Farad is adequate but not really allowing the the Farad to live up to its fully potential.
Ghent Audio and Audio Sensibility both offer some really nice options.
Or has anyone else found something else than these two which sounds “better” than Farads level 2 DC cables?Are these cables better than Farad level 2 DC cables?
