I guess the question will be , when will Taiko bring some form of DAC to market. Personally it was Lampizator that got me back into the digital game. The Pacific is a fantastic DAC. Yes mine was single ended. As for tube rolling I played with a few rectifiers but stayed with my KR 242’s. I now have a Horizon and a tube set that I prefer, do much so I have 3 back up sets of each tube. My entire system is tubes, so for my ears Lampi is what lights me up with my Extreme
It seems I will need to address this at some point in time in light of these mounting "rumours" :)
As you all know we have been advocating the use of the USB interface to connect to your DAC while most other server vendors advocate the use of SPDIF/AES/I2S and in a few rare cases Ethernet. The reasons for this are pretty straightforward.
You aspire to meet or exceed cd transport playback performance for 16/44.1 files at a competitive retail price level. This first issue you will run into is a quite obvious one, you need a very significantly larger amount of PCB real estate, functionality and processing power which require much more filtering to have competitive electronics noise levels. You could argue that a CD transport comes with additional expense for rotational stability and vibration control (jitter) but then you're disregarding the streamer hardware possibly being equally sensitive to this, but you do have the luxury of the absence of a motor. Then you need an interface to the DAC. Very low noise SPDIF/AES/I2S solutions have been around for decades with not much, if any, mystery surrounding their sound quality performance. And obviously, using the same interface as a CD transport, it becomes easier to approach a CD transport sound signature. However with a limitation of a 24/192 data rate over a single line, and due to how the interface works, increased noise levels at higher sample rates. Typically this interface will not sound better for higher sample rate files then 16/44.1 (note that the source master quality tends to exceed any of these differences at all time), and worse then 16/44.1 with DSD/DXD files due to the need of significant conversion processing. Ideally you have managed to have CD transport quality playback, for all sampling rates... To us this has been an unacceptable approach from day 1, which is why we went all in on USB. USB data packet rate is fixed and does not change with sampling rate, the interface is universal, the interface sound signature does not change with sampling rate, and it's the same for all receivers, or at least, that was the design goal... Today we know and have proven this is not true. Sure we have developed an USB card with noise levels at or below those of an AES/SPDIF/I2S interface without the jitter/timing sensitivities of those interfaces. But still there were deviations and discrepancies from expected performance. It took designing our own USB driver, querying all DACs our customers support, and designing our driver to be adjustable to... different implementations of USB receivers in DACs. This was quite an elaborate project, but as you have all witnessed the performance delta can be dramatic. However as you also all know by now is that the playback software has it's signature too, and Roon's changed over time. Roon sounds more expansive then CD transports, but also softer and less clear, some prefer this over CD, some don't. So we have XDMS now to level the playing field once more. For 16/44.1 (local file playback) XDMS on the Extreme sounds like a mix of CEC TL0 3.0 timing, Kalista colour shading and the bass of a Mark Levinson 31.5. Let's say what we have today is competitive performance at 16/44.1 to top flight CD transports and deliver on the promise of better performance at higher sample rates (again assuming corresponding master quality).
Where to go next?
All good so far, I'd say we've made steady progress, but, during this journey, exploring the USB interface, driving it to it's absolute limits, coding drivers, coding playback software, the idea came to bear there's room for improvement, considerably so, as further improvements in code are not possible due to USB interface hardware limitations. Yes we can and conceptually have an even better USB interface design, but still this will the same limitations, this kind of improvement would be similar to the "dumb improvement" of overkilling linear power supplies for a bigger multi box model Extreme without actually solving a "problem", without real progress or innovation.
So we took it upon us to embark on a very ambitious project of designing an entire new interface not hindered by the limitations of either the USB or AES/SPDIF/I2S interfaces. This project involves coding a whole new driver stack with corresponding software from scratch and a whole new hardware interface. We have not thought of a name for it yet but internally we refer to it as: TACDA and TACDD for Taiko Audio CPU Direct to Analogue and Taiko Audio CPU Direct to Digital.
The first product we have using this technology is actually close to release already, being a PCIe card with analogue RCA outputs, SPDIF RCA and BNC, and toslink, not that I expect anybody to be using toslink but it costs virtually nothing extra, maybe useful to hookup an A/V receiver?
We have talked to @Lukasz "Lampizator" Fikus who is open to incorporating this new interface into his DACs, to Jonathan Gullman of MSB who is willing to port this to their PRO/ISL interface, and have just approached Vincent Brient of Totaldac which would be a very nice next phase of this project.
Emile, I’m sure you’ve thought of this already, but why not go with Ethernet to the BPS, rather than Bluetooth. The integration of connecting data via BLE and Ethernet can be a bit tricky.
Well the reason for this is quite simple, even just a single RJ45 ethernetport with Phy produces more noise & uses more power then our whole Bluetooth controller including wireless transmitter/receiver. So then we'd need to go SFP and incorporate our switch design into the BPS, which would complicate things dramatically...
Well, I’m afraid I‘m too poor for the big battery power supply.
So I thought about futzing around with a fuse.
austinpop and romaz had done that and reported sonic benefits.
Otoh, Emile recently wrote: “… having to support problems caused by fuse swapping … “.
Yes, I have read as well his thoughts about those fuses possibly loosing their performance with switching on and off.
Still, I think about those fuses.
Which fuses made trouble? Did they bring damage to the Taiko extreme?
While I enjoyed all my conversations with Ed (hi Ed!), I don’t want to steal his time with rebooting/reinstalling/whatever due to fuse failures.
Which not?
Which were a good match, which weren’t?
thx in advance for your input!
Much has been written about that, I recommend to perform the following search:
Reactions: Pokey77
Interesting - could it be used to power more items in a stereo system over and above the Extreme, like a whole digital front end and excluding power amps?
Well if those are AC powered you lose some benefits needing to introduce an DC-AC inverter and then subsequently route it through the AC-DC conversion in your appliance again, but sure, it's possible..
Where to go next?
Now this is some wild shit!!! Talk about innovation! You are one wild cat Emile!!!
Very interesting, Emile. But why interface to another DAC like a Lampizator or MSB?
To improve performance? :)
But isn’t the “TACDA” a DAC? Why run the output through another DAC?
EDIT: the analog RCA being included threw me off, as it’s therefore doing an analog conversion…
We're not DAC designers, the innovation is in the superior interface, we've incorporated a Rohm BD34301EKV DAC chip because we thought it sounded best of the available "off the shelf" DAC chips and added a JFET class A output stage, but that's about all we could fit on a PCIe card sized PCB. Sure it may outperform 10-20K DACs but to directly compete with a top level DAC like a Lampizator Horizon, MSB Select 2, or Totaldac D1-12 is a bit much to ask for :)
Well I think my Nagra HD DAC X is the best available, at any price ;) - so how would I connect the new TACDA to it? I guess through SPDIF(BNC) unless you develop a custom interface?
The best reviews are here, in case anyone is interested:
Comparison against MSB Select:
He has a very thorough unbiased testing approach:
Reactions: MusicFellow
Where to go next?
No flies on you Emile. You keep going such that dust never collects under your feet. I love it
In an ideal world all DAC manufacturers would follow suit and incorporate our interface ;)
Right! You should contact Rene at Nagra. I’m happy to intro. you, if you’d like?
Until then, would you say SPDIF(BNC) as the ”best”?
What a way to wake up and read all of this new info. Speculation is easy and free and usually incorrect These last few pages of posts are filled with incredible and updated information and sets the record straight on so many accounts. This has been like a morning fireside chat with our fearless leader. I haven't even had a first espresso yet as the posts are good enough to fill a book.
@Taiko Audio
Emile, thank you for bringing all of us up to date and answering so many questions including several that weren't asked
What a treasure trove of information
Reading about those ever enlarging versions of the Extreme and the power required to run them reminded me at this Christmas season that if we had all bought one and used AC to power them on at the same time, it reminds me of a scene in Christmas Vacation. Watching this reinforces the need for a BPS :cool:
Where to go next?
Emile you are simply the best !
There are no other people in the industry except of you and Taiko trying to improve the SQ limitations we had for many decades !
Everyone sticks to the known formats and interfaces.
I waited for something like that most of my „ audio life „ .
I did personally few first in human procedures that are now used globally by others
serving cure for something we had no treatment so I understand the pioneering work you are doing and how this will impact audio industry.
Bravo !
Nothing on earth is going to give you a better feeilg than doing something „out of the box”.
Everyone in the industry will follow OR will buy rights from you to use it in their products !
Again this is by far the best news I heard for many dacades.
I cant wait to hear more news from you !
As we contemplate a cornucopia of innovations from Taiko, I think it’s important to enjoy the ride. By this I mean, experience each innovation in turn, for as far as you can, or prefer, to take it.
To use a car analogy, you could jump from a Corolla to a Ferrari, but it’s more fun to experience the models in between.
You also appreciate the gains more if you experience each step: Extreme -> Switch -> Router -> BPS -> TACDA (or however we individually chose to do it).
Personally, I think I’ll stop at the Switch (+ LPS). The sound quality is already superlative, and my financial outlay, at around $500K for the entire media room system, is where I should cap it. Maybe I’ll change my mind ;), but space is also a premium. I had to get very creative as to how to even fit the Extreme as a single chassis.
It’s great to have options and nice to see that Taiko is continually pushing the boundaries of what is possible.
