Site Founder, Site Co-Owner, Administrator
Im betting it's there for a reasonGet rid of the huge recess on the back..that'll save some $$
And I'll take the big boy....
Actually we do have 2 versions. Excuse the lighting as it’s dark outside now and I have to rush out soon for my 2nd Christmas day dinner:
190*150*40mm weight 7.5 Kg / 16.5 lbs
210*210*50mm weight 15.7 Kg / 34.6 lbs
The difference in the PCB sizes is caused by a more elaborate power regulation section. The cost saving is significant. We’re considering releasing both.
I'm not sure I understand the difference between the small device and the large one. Is one a switch and the other a router?
Recent Extreme purchaser (Thanks Emile and Bob). Was wondering if there was a Taiko power supply coming for the switch/router?
Thanks
Thanks
Will this smaller version only power the switch and router (not the Extreme)?We’re aiming at releasing a smaller version of our BPS (Battery Power Supply) in May. We’re most likely not developing a Linear Power Supply as there are so many on the market already.
Emile, the idea of a write-up is really fab. Really helpful, especially if it notes certain use-cases as well as characteristics and configs.
In my case, I am seriously considering NOT streaming on the main system any more. So selfishly, I have interest in understanding how the switch benefits the over-all sound/system...or if it does at all. Or maybe that will be rendered moot. Concepts like that.
Thanks again for weaving this into your holiday!
If so, when do you plan to release the big boy BPS that will power everything Taiko?
Wow! That looks very, very sharp!
Performance observations by Christiaan will be helpful. You explained awhile ago how well Roon excelled with the switch and how you "expect" it to surpass with XDMS and you were not there yet. This creates a little ambiguity.We’re fully aware the topic is in need of thorough explanations and/or guidance. It’s uncharted terrain for the vast majority of us.
The copper is killer!!Wow! That looks very, very sharp!
Decisions, decisions -- copper or chrome? Which do I like more? (Which can I afford??)
Steve Z
I am still wondering, if a smaller BPS would fit into the standard Extreme case. Eg one that allows only say 2-3h of listening instead of 6-8h (just picking numbers here) for the big stand-alone version, but still can power Extreme, switch and Router and because of not needing an expensive second chassis would only cost about 40-50%. Not sure though if the circuit board if the BPS etc would fit...Yes.
Same time (May).
I don't think 2-3H will cut it with most. I'm at 9 hours today, too damn cold to work outside. This is a much better alternative!I am still wondering, if a smaller BPS would fit into the standard Extreme case. Eg one that allows only say 2-3h of listening instead of 6-8h (just picking numbers here) for the big stand-alone version, but still can power Extreme, switch and Router and because of not needing an expensive second chassis would only cost about 40-50%. Not sure though if the circuit board if the BPS etc would fit...
