Can I ask who told you it would not work with Cisco?THX - But I have been told it would not work with a Cisco switch - in my case Cisco Meraki Go 8 Port Switch (GS110-8-HW-EU).
Any suggestions for an alternative SFP?
Torben
Torben
I know. For a low volume product like an Audiophile converter I guess it would be financial difficult to start from scratch. So why not start with a good base and work on feasible improvements?This ADOT FMC is nothing more than a rebadged 10Gtek one it seems…
You don't have to use more expensive Cisco SFPs, but it must be Cisco compatible, which some others are. Of course other compatibility aspects still apply (wavelength, type).
My 2 Sonore modules are placed between my Paul Pang Switch and my LinQ streamer.
@Thieliste 2? Only need one - from switch to (Fiber Optic Patch Cable) to Sonore optical modules Deluxe v2 to DAC (LAN)
That’s right.His Paul Pang Quad Switch doesn't have a SFP port so you need two Sonore optical modules Deluxe v2.
With this LPS : https://gear.nativedsd.com/product/the-dodo-dual-linear-power-supply/How do you power them?
Torben
If you guys had to choose between Ethernet Switch and Optical modules to place between router and streamer, which do you like best Switch or optical modules alone ?
I am sure there are even “better “ on the market. But how to know witch?
Strange. No problems during the weekend but during the weeks.…..Ok guys, just found out my problem.
It is my PP Switch that causes these huge drops in speed when paired with the 2 Sonore modules.
This is very strange because when i do speed tests from PP Switch speed is maxed out.
The 2 Sonores Modules connected directly to the router without Switch same thing great speed.
